Question about Vehicle Parts & Accessories
Passlock light keeps coming on steady
I have a 2008 GMC Sierra. It starts just fine and runs just fine. The ONLY issue I have is that the Passlock/security light on the dashboard will come on shortly after starting the vehicle and stay on until I turn it off. Is there a fuse or relay or something that could be causing this?
    Top Expert:
  • 5,332 Answers
If the light comes on after you start it than there is a problem with the Passlock system. You will need to pull trouble codes to find out what is going on. You will need a high end scan tool to do this. The good news is Passlock system is somewhat disabled when the light is on and there shouldn't be any issues getting the engine to start. The bad news is if the battery goes dead or it is disconnected the vehicle will likely no longer start. So its a good idea to get this resolved as soon as possible.
Posted on Jul 31, 2013
  • 12 Answers
SOURCE: the vehicle starts , but immediately dies.
I would look at the tach wire it is probly not getting signel back to the remote starter usaly a purple wire on remote starters
Posted on Mar 02, 2009
SOURCE: Passlock II issues for 99 Tahoe
turn key to start position for 10 minutes and it will reset passlock
Or, once you're tired of being stranded for 10 min every 6 weeks or so, try the following:
Here's the "fix" I did for my 99 tahoe. Took the cover off the steering column, unplugged the sensor from the cylinder *while* the car was running. it's a 3 wire plug red w/ white, orange w/black and yellow. From then on, the car will always start and ignore the sensor. The only negative is the security light stays on. Replacing the BCM only postpones it from happening again if the problem is the resistance in the ignition lock cylinder. Check out the following links. Good luck.
http://car.justanswer.com/for/ce07-bypass-lock-sensor-1998-chevy-tahoe
http://general-motors.pissedconsumer.com/gm-passlock-ii-system-has-major-inherent-design-flaws-20080502119601.html
Posted on Mar 18, 2009
  • 87 Answers
SOURCE: check engine,airbag and wrench lights come on the dashboard
Sound like they tapped into a low voltage ingnition wire or a data bus wire. It needs to be doubled checked for correct wiring. These new cars are very sensitive computer systems, its more than likely an improper wire.
Posted on Jun 04, 2009
SOURCE: My 2006 Mazda 3 occasionally will not start.
i was told by my rep @ mazda that there may be corrosion on the power wire connected to the starter and it should be checked and cleaned
Posted on Dec 16, 2009
  • 355 Answers
SOURCE: security light stays on and somtimes it will turn
The security system (VATS/PassKey) is having problems, it's typical on those cars. You can find a great write-up here: http://newrockies.ca , it was the only thing that saved my Park Avenue.
Posted on Sep 10, 2010
Truck runs fine then dies while driving then will start back up and run ok.
About 56,700 results (0.76 seconds) Search Results
    GMC Sierra 1500 Questions - Truck suddenly stops running ...
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
    1998 1500 5.2 Shuts Off Randomly - CarGurus
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
    GMC Sierra 1500 Questions - started stalling and dying ...
    CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
    Engine Dies and Then Starts Right Back Up
    www.justautorepair.com/chevrolet/blazer/stalls-starts-up
Feb 04, 2016 | 1997 GMC Sierra
No crank no start
Chevy Impala 2008 won't crank and won't start, fix found ...
? 1:43
https://www.youtube.com/watch?v=ITvU_vXMrDY
Nov 26, 2012 - Uploaded by Artome001
Chevy Impala, 2008, does not crank or start. ... 2003-2007 Chevrolet/GMC Silverado/Sierra No Start/no crank/electrical issue FIX - Duration: ...
2006 Chevy Impala / MC No Crank/start FIXED - YouTube
? 5:42
https://www.youtube.com/watch?v=dGF0Ohbj5xg
Jun 8, 2015 - Uploaded by Jair Duarte
2006 Chevy Impala / MC No Crank/start FIXED .... 2003-2007 Chevrolet/GMC Silverado/Sierra No Start/no crank/electrical issue FIX - Duration: ...
Passlock Security system... - Discussion on Topix
Jan 16, 2016 | 2003 Chevrolet Impala
Why won't my 2008 gmc sierra start?
I think I found your issue.. is the security light on?? check out this site your car is on the list ..They sell a part that you an install yourself.. its cheaper then going to a shop and having them do it
Jul 28, 2014 | 2008 GMC Sierra 1500
Security light and instrument cluster issue 2000 gmc sierra 4x4
Have you recently changed the dash cluster out? If so, you may need to bring it to a dealer to have it programmed. Many of the GMC/Chevy dash clusters wore out and needed to be changed and many people tried this themselves only to bring them to be programmed by a dealer.
May 03, 2014 | 2000 GMC Sierra
How do you reset passlock?
Turn the key to run position (engine not running) theft light will flash a few times and stay on. Leave for approximately 10 minutes (may take up to 20 min.) And the theft light will turn off. Repeat these steps 3 times. After the third turn the key off and attempt to start.
Apr 15, 2014 | 2003 GMC Sierra
95 gmc sierra won't hold steady rpm
Sounds like wiring problems with the engine harness.
The oil pressure not working could cause the hard starting problem.
The idle problem could be a faulty idle air control valve or a vac leak.
I would start with the check engine light and find out what the codes are.
Oct 04, 2012 | 1995 GMC Sierra
My security light stays on & won't let my 99 gmc 6.5 diesel sierra start any solutions
Yes, the system is called Passlock, and malfunctions regularly. Go to this link for an explanation of how it works, plus some tricks and tips on how to reset it, or bypass it.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Mar 27, 2012 | 1999 GMC Sierra 3500
After sitting in garage unused for 2 weeks 2008 gmc sierra 2wd starts fine, but ABS light stays on, in D clunks into gear then check engine light came on. 18000 miles. had no issues when parked
That is really low mileage for issues but clunking into gear is a symptom of a bad universal joint on your drive shaft. Does it clunk in D and R?
Nov 26, 2011 | 2008 GMC Sierra 1500 2WD
1999 grand am 'security light' stays blinking - cant start car
1. Attempt to start the car, let it stall, but DO NOT turn the key off! Leave it in RUN.
2. Wait 10 minutes or until the Theft System light glows steady instead of blinking.
3. Do not turn the key off, but start it immediately.
4. This should reset your Passlock system.
The other issue is that the BCM harness is known to corrode and will cause the passlock to fail and will lead to a no start. Check the BCM under the glove box, the bcm had somehow get's wet and the terminals corrode. Sand down all the corrosion that you could and put the bcm back into place and the car should started up fine and worked normally if done right. ONLY DO THIS IF YOUR SECURITY LIGHT STAYS SOLID AND DOES NOT RESET FROM THE ABOVE INSTRUCTIONS.
Thank you for using fixya and keep us posted.
Nov 25, 2010 | 1999 Pontiac Grand Am GT
I had an issue with the passlock system. The
did you have the BCM programmed to the new key? the dealer has to do that.
Jul 27, 2009 | 2000 GMC New Sierra 1500
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
