Question about HP Office Equipment & Supplies
Printer I can't get my printer to print
    Champion:
  • 247 Answers
Check data cable if ok check no paper jam if ok check power adaptor if ok check pc printer software matches printer series if not get model series of printer and download from net search engine and upload to your pc if all ok check the printer has genuine ink cartridges and all will be ok
Posted on Jul 19, 2013
I don't understand the my printer was working perfect it pass the aliment but I turn off the printer for few weeks and now when I turn on my printer it won't print black it won't pass the
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 31, 2012 | HP Photosmart C6100 All-In-One Printer
Printer is paused all the time
Hello, sounds like your drivers are messed up, reload them to the computer or the connection cable maybe bad. If neither of these fix then the printer is bad.
Sep 05, 2012 | Canon PIXMA MX870 Wireless Office...
Won't print in black
  1. Open the Properties / Preferences window for the printer.
    For Windows 7
    • Click 'Start' from the bottom left of the Windows screen, and 'Devices and Printers .'
    • Click your right mouse button on the listing for your printer, and then select 'Printing Preferences...' from the menu that appears.
    For Windows Vista
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    For Windows XP Home Edition
    • Click / Select 'Start' from the bottom left of the Windows screen, 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/ Me/98 (if applicable)
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. De-Select the box for 'Grayscale Printing'.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Aug 27, 2012 | Canon PIXMA iP4300 InkJet Photo Printer
Need only black to print from HP Color Laserjet 4700 printer
on the print page just before printing , go to properties and make black the default color
Jun 04, 2017 | Office Equipment & Supplies
Prints half page
Hi
Make sure the printer is set as the default printer on your machine.
Check the printer which the application you're printing from tries to access and make sure its your printer.
Try printing from another application.Can't print?Check the compatibility of your printers driver and the Operating System you're using.
Also find out more about the program you're using and its support.
Check the printer settings including set print paper sizes.
Download the latest drivers for your machine.
Feb 29, 2012 | Epson NX510 Printer
Printer won't print in color, no matter what i try.
Did you try setting the color printing in printer properties.
If you have XP;
Open 'Printers and faxes'.
Right-click your printer and select 'Properties'.
Click 'Advanced' tab.
Click 'Printing Defaults' button close to bottom.
Select 'Paper/Quality' tab.
Select 'Color' option.
Click OK until all dialog boxes are closed.
Sep 15, 2011 | Lexmark X3650 Printer
When i print from hp deskjet D1560 it dose not print. It automatically shows offline when i print even though it is not offline. And it dose not print self test page also. pls give an instant...
Go to system settings and select the 'Printer' option.
Right-click on the printer and enable the 'Use Printer Online' function.
Cancel all the printing jobs till that moment and redo the process.
Sometimes the 'Printer Offline' message occurs due to a 'Job Stuck' issue.
Check all network connections and functions.
Be sure the network interfaces work properly.
Turn the printer off and on to see whether the device is working properly.
Aug 19, 2011 | Office Equipment & Supplies
My printer won't print. my computer is hooked up to it, and it doesn't give any error messages. it just doesn't do anything.
Go to Control Panel/Printers. Right click on your printer's name, and hit Print Test Page. If printer prints a page out, then the problem is likely with the software you're using to print - make sure you have selected the right printer in the dropdown. If the printer's name doesn't show in the Printers folder of Control Panel, the driver for it has not been installed. Do so and try again.
Jun 18, 2011 | Lexmark X2670 All-In-One Printer
My Dell V505 printer won't print documents from the computer, when I press print the printer prints a page of dash's and ticks. there is ink in the cartridges. i've disconnected the power....
Turn the printer off.
Disconnect the AC power.
On your computer, click Start
Click Control Panel
Click Printers
Select the Dell Printer
Uninstall it
Restart your computer
Turn the printer on
Allow the computer to reinstall the device-device for the printer.
Print a test page.
May 09, 2011 | Dell AllinOne Multifunctional (v515w)...
18 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
