Question about Shuttle XPC SD32G2 Barebone
Power flashes on for a second and then turns off completely
My computer won't turn on and it just flashes on for a second, then it will completely turn off. It only flashes on for the first time I turn the power on, the second time if I push the button to turn it on it won't flash on. What could be going on?
    Novelist:
    Scholar:
  • 100 Answers
Actually, it can be another source too. If you don't hear any beeps from your computer, the (TFT)monitor might be the source.
The result is a booting PC, the monitor will turn on, but within seconds turn off again. In the background the PC is running just fine, but because you don't see anything at the monitor, you might think it's your PC.....
In other words, it's good to add more specific details.
Posted on Oct 14, 2013
  • 3,799 Answers
The most likely problem is that the power supply has failed.
Posted on Aug 10, 2013
Sharp Mebius won't boot
I suggest that you remove the battery and use the charger only in turning on your computer. If it turns on just fine without the battery then you would need to replace the battery. If it doesn't then it's either the motherboard or the charger which has a problem.
David
Jun 10, 2013 | Sharp Mebius Computers & Internet
Monitor won't turn on after a few hours of being shut off
If it EVER works, then the problem is not a failed part, but a weak part. The most likely component type to give you such problems are capacitors. But very few repair techs know how to find such problems, and even fewer have the equipment needed to find the bad one(s) in-circuit. The failure mode is high ESR (ESR means Equivalent Series Resistance). The lower the ESR, the better. Capacitors with high ESR cannot stabilize circuits which demand high pulse currents, such as in switch mode power supplies.
Apr 24, 2017 | Generic Computers & Internet
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
Laptop Fan and Power Indicator won't turn off.
Are you sure you are turning it off completely. Sounds like you have it sleeping or hibernating. Press and hold the power button for 15 seconds or so, it should power off completely.
Mar 29, 2012 | Computers & Internet
My PowerMac G5 won't recognize the monitor that goes with it
check your video cable ends for bent pins or debris, then make certain that they are plugged in straight and tight.
Mar 06, 2012 | Apple Power Mac G5 Desktop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
Shuttle XPC SD32G2 Barebone Logo
94 people viewed this question
Top Shuttle Computers & Internet Experts
David
David
john smith
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
