Question about Garmin GPS
Garmin 4208 Marine Transducer Problem
When we first turn on the unit everything functions correctly, After a couple of minutes we get a message saying the transducer is disconnected and the power cord goes from green to flashing red
    Sergeant:
  • 288 Answers
You either have a faulty head unit, bad connection between the transducer and head unit, or a faulty transducer or transduced cable.
Posted on Sep 12, 2013
  • 16 Answers
SOURCE: fish finder
You have either the DSM250 or DSM300 digital depth sounder module installed. The C80 is not seeing it.
There is an LED status light on the DSM. For starters, it should be lit either red, yellow or green to confirm it is actually powered on. We are hoping for a green light.
Double-check the cable between DSM and C80 for tightness. Also double-check the DSM's power cable for tightness.
The DSM's are sensitive to voltage level onboard. Make sure the DSM's connections to the circuit breaker panel or battery are tight and clean. Double check with a multimeter the there is 12V DC available to the DSM.
Let me know what you find.
Posted on Dec 28, 2007
SOURCE: navman 4500 fish finder w/transom mount transducer
I finally got an email reply from Navman. If the unit is less than two years old (mine is not) they will repair it. If it is over two years old, or if you can't prove that it is less than two years old, you can ship it to them and they will repair it for the low, low price of 355 US dollars.
Pretty nice of them since it appears these units are highly problematic isn't it? I am wondering if they guarantee their fix, or just have you on the hook for another 355 dollars later.
Good Luck Everyone,
Walt
Posted on Apr 30, 2009
  • 597 Answers
SOURCE: installing an old used lowrance fish finder
I don't think your old fish finder is the LMS-332C GPS Receiver listed above in the description. You don't need the speed wheel for the fish finder to function just the transducer and transducer mount. You should mount that on the back of the boat towards the center but not too close to the motor and not too close to the side of the board. Don't let it hand below the level of the boat. That should keep it from getting hit by the trailer or dragging on the bottom. Try to make it as level as possible. The green and white wires may be for the speed wheel but i'd need a model number for clarification. Hope this helps.
Posted on Jun 02, 2009
SOURCE: Transducer not connected
my 947 c says transducer not connected
Posted on Feb 11, 2010
  • 2926 Answers
SOURCE: my fishfinder lowrance x85 the
It is not the transducer. the transducer just provides the sonar reading back to the display. The issue is with the display head unit. Have you tried to adjust the contrast for the fading? Does the screen disappear after awhile? Is the head unit mounted close to other navigation equipment, such as a Compass that may cause interference?
Posted on Jul 24, 2010
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
Garmin 300c fishfinder will go from correct depth to 0.0 ft while traveling.Have to turn it off and restart. It is on Hurricane deck boat 198. It is located between engine and leveling tabs.
My experience as a user is that turbulence around the transducer can cause mine to flash and the depth to remain static.Is your fault affected by speed? Sounds to me that you have a faulty connection causing the transducer to "not register". I'd check connections and also the integrity of the transducer. Hope that helps...
Best of luck
May 28, 2014 | Garmin FISHFINDER 300C NIC ()
Garmin 100 echo stays in simulate mode. Is there a setting to change it to live mode?
1 turn off the simulator in the menu.
if that does not work
2. Check the connection to the transducer, if it is unhooked or corroded, clean and reattach the connector, the unit will stay in simulator mode if it does not detect a transducer attached to it
Apr 21, 2014 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Garmin echomap 50 keeps cutting in and out
Loose or corroded wiring and or connections.
Jul 25, 2013 | Garmin echoMAP 50s with Transducer
Transducer Error
You either have a fault in the head unit, connection to the transducer, broken wire in the transducer cable, or a faulty transducer.
Jul 20, 2013 | GPS
Garmin 541s transucer, unit problems
Sound like the transducer is catching air.
May 10, 2013 | Garmin GPSMAP 541s
I recently charged my battery and since hooking it back up to my fishfinder it constantly says supply voltage too high transducer turning off. ive tested the battery and its perfectly fine.
Maximum voltage for that unit is 33V. Test the voltage with a multimeter at the fuse block or as close to the unit as you can. If you are reading less than 33 volts than your voltage input is fine and you need to contact garmin for a repair or replacement if your unit is still under warranty.
Also check your connections at the battery; make sure everything is clean and that you do not have any + and - wires switched.
May 22, 2011 | Garmin FISHFINDER 300C NIC ()
My marine speed transducer needs to be replaced. I have a Beneteua 351 which is 16 years old. I have cleaned the transducer several times and then reinstalled. It will work for a couple of minutes and then...
Yes. You need to make sure you get the same transducer though. With you system being that old, you may have a transducer that is old where there is not a direct replacement. You need to make sure you get the correct transducer. You may need to get a "flapper" kit to update your housing to the new style.
Jun 15, 2010 | Raymarine St300/P371 Speed Nylon Thru Hull...
Raymarine ds500x brand new works good but will give false bottom readings occasionally corrects itself fairly quickly 30 seconds to two minutes wondering why it does this and how to correct it
If the transducer is not correctly mounted this may happen due to air, etc. If the unit never gives a depth reading that looks like dashes
( - - ) then there is likely nothing wrong with it aside from the transducer placement.
Aug 06, 2009 | Raymarine Ds500x Color Fishfinder: Ds500x...
On the GPS Garmin the radar screen shows our boat turned the wrong way. How do you turn the boat around on screen?
My husband moved the boat slightly and it seemed to correct the radar screen somewhat. He is working on the whole boat at present so didn't want to take it completely for a drive down the river. If we have further problems we may call in or use the web site.
Thanks,
Farrar
Jun 23, 2009 | Garmin Gpsmap 4208 Network Bundle
GPS Logo
90 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
