Where can I get a manual for the item below - Heating & Cooling
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model is "the item below"?
Posted on Jul 19, 2013
Kenmore Elite 110.22992 Won't agitate properly. Can't find way to get agitator housing out of machine.
In the exploded view on SearsPartsDirect it shows to remove the cover and there is a "agitator bolt" under it. Item # 22 in the picture below is the cover and the bolt is item # 2. The dogs that are usually bad are # 5.
Feb 06, 2016 | Washing Machines
My generator is getting no fire to the plug
The unit has a magneto that is item 16 part number
ETQ1200TG33 on page 22 of the manual link below. You will have to start looking at wires from the magneto / electronic ignition unit to the engine off / run switch for grounds. The unit also has an igniter inside the control panel that is item 2 on page 24 of the manual. The engine run switch is item 4 same page. The high voltage set (coil) is item 28 of the manual link below. Any ONE of these can cause the problem. I would first check the start run switch... then start looking for system grounds in the wiring of the ignition circuit.
Eastern Tools support number is here:
For repairs and missing parts please contact customer support at 1-888-908-6200
Manual is here:
http://easterntools.com/manual_pdf/tg1200_manual.pdf
Thanks for choosing FixYa,
Kelly
Sep 22, 2011 | Eastern Tools And Equipment 1200 Watt...
Freezer is forming frost around the light fixture located in the ceiling of the freezer compartment. We must manually remove the frost approximately two times per week.
If you are certain that the evaporator fan is running then your automatic defrost function has stopped working.
There are 3 things that cause it to stop working:
1. The defrost control
Item 801 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5206998&diagram_id=26604625#d26604625
2 The defrost heater
Item 826 above link
3. The thermo disc Item 621 above link.
4. The bi-metal thermostat (closed below 60 deg F)
Item 4 can be tested for continuity at temps below 60 deg F.
Item 2 and 3 can be tested at room temp for continuity.
Item 1 the main board controls the defrost cycle which turns the defrost heater on and off.
Primary suspects would be the defrost heater and thermo disc.
Shop areound for the heater if you find that is bad... the link I posted that heater seems VERY expensive to me. The heater PN: WR50X10042 I note prices in the range of $115.00 - $171.00
This PN defrost heater has a history of repeated failure.
Kelly
Sep 08, 2011 | GE Profile PFS22SBSS Bottom Freezer French...
We cannot find the directions on how to clean the Braun Series 7 razor
You will find the user manual for Series 7 shavers at shaveroutlet.com. Click on the link below
http://shaveroutlet.com/shavers/braun-790cc-series-7-pulsonic-shaving-system.html
When the item page opens, click on 'user manual' just below the item price
Jul 18, 2011 | Health & Beauty
Drain pan overflows weekly - compressor hot to touch model FRT18B5JMO 3 years old
Hi and welcome to FixYa, I am Kelly.
I note that this unit has a rear coil condensor on the back of the freezer and that there is not a cooling fan.
In the drip pan Item 26 of the manual below there is a tube that is item 87 also in the parts manual below on pages 8 (picture) and 9 (part numbers). Make sure the tube 97 is above / resting in the top of the drip pan item 26. That helps evaporate the water.
If your getting lots of ice build up on the evaporator coils each week you need to make sure the freeser door gasket is sealing properly. It should mate to the chassis all the way around the door. Any gaps will cause excess ice build up and more water will be seen during each automatic defrost cycle possibly over-filling the drip pan.
Parts manual is here:
http://www.hammerwall.com/Manuals/Frigidaire/Description/FRT18B4AW8/Frigidaire%20Top%20Freezer%20Refrigerator%20Parts%20And%20Diagrams/5995398152
You will have to click this link then enter a 4 - 6 digit Captcha to download the manual below
http://www.hammerwall.com/tempmanuals/5995398152.pdf
Kelly
Jun 27, 2011 | Frigidaire FRT18B4A Top Freezer...
I need a user manual .Can't find in Yahoo.com .Not
The Phoenix User Manual is available in electronic format from either of the two locations below:
• When Phoenix is not running from your Start Menu > Programs > PhoenixRC > User Manual folder
• From within Phoenix by clicking the Help > User Manual item on the Main Menu Bar
There are also many small green "?" help buttons on the top-right of the program menus. Clicking these will take you to the User Manual at the correct section for help on this item.
Jun 17, 2011 | Phoenix R/C Pro Flight Simulator V2.5 for...
How can i delete the memos i recorded?
A.To ERASE
1st select the folder of deleting file(by pressing FOLDER button).
2nd press and hold " ERASE" button,
3rd within 10 second select the item you want to erase by rotating "PLAY/STOP SEL" wheel,
4th within 10 second press "ERASE" button. selected item is erased.
if this method will not work, then , the item is locked. To remove the lock folow below step B
B.TO UNLOCK
1st select the folder containg the item ( by pressing FOLDER button)
2nd press MODE button until " LOCK" or " UNLOCK" flashes
3rd within 10 seconds select the item by turning "PLAY/STOP SEL" wheel
4th within 10 seconds press the same " PLAY/STOP SEL ' wheel
item will unlock
then for deleting folow method A
below link is user manual
user manual panasonic RR-QR240
best of luck keep smiling
Jan 14, 2011 | Panasonic RR-QR240 Handheld Digital Voice...
Can I get a manual for a Jandy aqualink rs?
You can get the manual for the item on the link below.
http://www.southshoregunitepools.com/resources/manuals/jandy_installation.pdf
If that is not the right one can I get the model # or you can go to the link below.
http://www.jandy.com/html/productsupport/#manuals
Good Luck and please rate 4 thumbs up for the free answer
Jun 20, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Chain oil pump does not work when pumped. Eager ****** MAC 100 series
Your Eager Beâver model number is 600016. There are many prefixes and suffixes. The one below I used when repairing a similar problem with my Mac 110 (earlier version of your saw). Both the automatic and manual oilers work now.
I get the best results for new McCulloch parts here:
This is a little complicated so I am going in small steps.
M & D Mower
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “18-600016-27”
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
See “General Assembly” print
Item 33; pn 85557; Oiler body; most likely failure, on bottom of Item 31
Item 31; pn 217755; manual oiler piston; It pulls through the top of the tank. I ordered a new one but got Item 36, they were the same pn, I complained, seems they fixed it.
See “Powerhead Assembly” print
Item 07; pn 219989; oil pump assembly
Item 04; pn 217168; pump/bar pad connector (hose)
Item 05; pn 217167; pump/oil tank connector (hose) The new one was to long, I used the old hose. I have an earlier model.
Item 17; pn 110653; O-ring
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 06, 2010 | McCulloch Garden
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
