Question about Microwave Ovens
Panosonic Microwave working but not heating
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
See this instruction and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#2#ixzz2ZYTePT1u
Posted on Jul 20, 2013
How do you unlock the panosonic microwave
hi Barbara.
this is what i could find out.
. Press the "Stop" button three (3) times.
or read up more at this link.
You are now ready to use your new Panasonic Microwave Oven. When you first turn on your microwave oven and under normal operation the "CHILD LOCK" feature is off. If "LOCK" or "CHILD" appears on your display . . . Press the "Stop" button three (3) times and the "CHILD LOCK" will be turned off.
set-up guide - Panasonic
ftp://ftp.panasonic.com/microwaveoven/om/set-up_guide_en_om.pdf
How do you unlock the panosonic microwave Google Search
Dec 02, 2017 | Microwave Ovens
My Panosonic dimension 4 microwave has started but a "refer to user instructions before use" message up. It still works fine but do you know why it's doing this??
It should only do this after it has lost power and then regained power. Are you unplugging the device in between uses or using a surge protector/power strip switch to turn off the power between uses?
It is just a reminder to new users that they should refer to the manual. It is not reporting that there is anything amiss with the device.
Panasonic NN C994S Operating Instructions Manual Let Start To Use Your Oven
Dec 16, 2015 | Microwave Ovens
Panosonic microwave shuts off after 3 seconds
That is an error saying you have a bad HV Inverter.
Apr 27, 2012 | Microwave Ovens
Can I replace the lamp in a panosonic microwave oven model NN CT 857
Hi.
The lamp replacement requires complete removal of the oven external casing. The oven must be tested for radiation leakage after the repair. The replacement must be done by a trained technician. Disassembling procedure is illustrated on the service manual available here: Panasonic Service/repair manuals,schematics.
Regards.
Ginko
Dec 15, 2011 | Panasonic Microwave Ovens
MY PANOSONIC INVERTER SHUTS DOWN AFTER 14 SECONDS MODEL # NNCD989S
Check again.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
Order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 29, 2011 | Panasonic NN-H275SF Microwave Oven
I need the panosonic microwave/convection cookbook for the NN2909/NN2959 700 watt. Where do I go? Kay wspheres@frontier.net
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 03, 2011 | Microwave Ovens
Ge spacemaker microwave when i plug it in comes up with PF on the screen and does not work at all,it has power and the light inside is on,i can press the 3 minute button and the microwave will wor but that...
ther should be instrustions manual sound like mocro is working suspect control panel it needs 2 be reset how read manul panosonic push stop 1 at same time menu comes up push reset this is a minor problem hopes this help u
Jul 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Panosonic nn-t790 microwave
I pulled the top and sides (one piece) of the microwave. Near where the 110 volt line goes into the unit is a standard fuse ( 18 amp). I used an ohmeter on ther fuse and determined that it was not working and replaced it. Problem solved - unless it blows again.
Nov 06, 2008 | Microwave Ovens
Microwave Ovens Logo
29 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
