Question about Boating
Garmin 4108 transducer disconnected after a few minutes of working
Garmin 551s sonar stopped working, no bottom definition or ability to see fish GPS charts and speed all work It shows 3 step image repeats top of the screen / water surface has the transducer packed
Check you transducer cable route and connections. Look for kinks, punctures, & tears in cable. Visually check the transducer for damage. #2 check the units operation on a friends boat with the same set or research a local marine repair shop to check ops. Best of luck on the problem.
Jan 11, 2016 | Garmin Boating
How Do I reset a garmin B175L transducer
There is no "reset" for a transducer. It doesn't have internal electronic circuits and no power source. Think of it as an underwater speaker.
Aug 29, 2014 | Garmin B175L Bronze Tilted Transducer 20...
Garmin echomap 50 keeps cutting in and out
Loose or corroded wiring and or connections.
Jul 25, 2013 | Garmin echoMAP 50s with Transducer
Transducer Error
You either have a fault in the head unit, connection to the transducer, broken wire in the transducer cable, or a faulty transducer.
Jul 20, 2013 | GPS
Garmin 4208 Marine Transducer Problem
You either have a faulty head unit, bad connection between the transducer and head unit, or a faulty transducer or transduced cable.
Jul 19, 2013 | Garmin GPS
My Garmin 400c dual beam transducer keeps freezing up, it will flash "0" depth and then go to a "updating software" screen.
check your battery voltage. Low voltage can cause errors end prevent the sonar from starting up. If charging the battery doesn't work then contact garmin for a replacement.
Nov 30, 2010 | Garmin Fishfinder 400c With Dual Beam...
Have just installed a Garmin 140 on a tracker alum. boat. I have the transducer what appears to be at least 3/8 " below bottom of transom. I lose the bottom at least 40% of the time. Do I need to go...
I would recommend having the back part of the transducer a little higher (toward the sky) than the nose of the transducer. When I say a little, I mean a very slightly. This way the nose of the transducer pushes the water and any bubbles away from the face.
Sep 07, 2010 | Garmin Fishfinder 400c With Dual Beam...
Depth Sounder does not display depth
I will see if I can get mine off the hull for testing. Still have found no procedure. Thinking about just replacing the sounder with another unit.
Jul 05, 2008 | Garmin 185 Sounder GPS Receiver
Transducer
I have the exact same problem. Were you able to solve your problem???
May 12, 2008 | Garmin GPSMAP 3210 GPS Receiver
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
