Acer aspire l3600
My tower switched off one night and just wont turn back on although the fans are working
    Sergeant:
  • 396 Answers
You may have a bad power supply. Did you turn it off, or did it go off by itself? Do you hear any beeps when you try to turn it on? Those may help you figure it out. If nothing happens you need more help, like a technician in person.This may be simply the power supply, or the motherboard may be done for.
Posted on Jul 21, 2013
2 Suggested Answers
nonontech
  • 4737 Answers
SOURCE: i want to get driver tv tuner for acer aspire
It's a problem for us to assume since you didn't mention the Operating System installed on the Acer Aspire... moreover there are two types of tv tuner card that comes with this model. I hope you'll not mind letting us know all these next time so that we can help you better.
If the operating system install on your system is Windows 7 the click the below links to download
Acer Aspire L3600 Connexant Tv Tuner driver for windows 7
Acer Aspire L3600 Yuan Tv Tuner driver for windows 7
Once you click the link, download will automatically begin. You'll need winrar or winzip to extract the files. Extract the files and run the setup or as per your convenience.
Acer Aspire L3600 Yuan Tv Tuner driver for windows vista
Currently, there's no drivers available for windows xp but you can still run it by using the "Device Manager" > "Update Drivers" wizard after extracting the windows vista drivers.
Good luck.
Thanks for using FixYa.
Posted on Jul 15, 2010
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    I have a acer aspire T135 and when I turn it on to boot I get the red and green light with a loud whirring noise from the cpu anyone know what is happening and how can i fix it please
    sounds like the cpu fan and that would also explane the green then red lights also open the tower access panel but first unplug the unit,wait 30 secounds or so plug the tower back in then look at the fan sitting on the motherboard or main processer see if it turns on and make sure it keeps running they tend to start then if there is a problem they eigther don't turn on at all or turn off a few secounds later Im thinking later would explane the lights
    Dec 17, 2010 | Acer Aspire T135 PC Desktop
    I want to get driver tv tuner for acer aspire l3600
    Good luck.
    Jul 08, 2010 | Computers & Internet
    My Acer l3600 Power Lead is faulty - is it
    No. It's about 90-100 volts different.
    Oct 29, 2009 | Acer Computers & Internet
    My new acer aspire tower has an anoying hum. Is this normal?
    Hi Rick,
    Ideally there will be some amount of noise emanating from any system, so its normal. The noise factor can be attributed to various components within your tower. Typical components that generate noise are:
    CPU Fan - It usually runs at a speed of 1500 rpm
    Hard Drive - There are circular metallic discs in the hard drive which run at a speed of about 7200 rpm for normal hard drives
    Video Card Fan (if there is one)
    SMPS/Power Supply fan
    However, if the noise is very audible then you can try the following:
    - Ensure that your tower is kept on a flat surface
    - There are no obstructions around the power supply fan (found at the back of your tower)
    - Power supply provided is proper and coming through a spike buster
    If you feel that the noise level is high, then I would recommend contacting Acer support as it may be a problem with one of the fans or the way your motherboard has been fixed within the tower.
    Jul 07, 2009 | Acer Aspire™ T180 PC Desktop
    Acer aspire L3600 unusual power problem
    sounds like a hard drive issue. reformat your hard drive and put windows back on it.
    May 09, 2009 | Computers & Internet
    Do i need the cables for the router?
    To go Wireless on your desktop Acer Aspire L3600, you should consider buying an USB Wireless Adapter. It could be any brand as long have same frequency with your Netgear (i.e 2.4 Ghz/5.8 Ghz)
    P.S.: If this information was helpful, please rate this solution.
    aymloekh0fg4hpz2e87n86udvs4fowqwshuaaaaasuvork5cyii=
    Apr 01, 2009 | NetGear DG834G Router
    Acer 3100 screen wont turn on.
    Have you tried hooking an external monitor to the system? If that works you may have accidently switched the screen to an outside monitor. Or you could have a bad connection. Try starting in safe mode and see if it works.
    Jan 19, 2009 | Computers & Internet
    Restore factory settings to acer aspire L3600?
    you need to press the Alt and F10 key together when u restart ur system on the initial power on screen
    Mar 20, 2008 | Computers & Internet
    Computers & Internet Logo
    David Payne
    David Payne
