Question about Kenmore Dryers
Kenmore dryer I have a kenmore elite H4 and condensation is build up inside the dryer. I was assuming the door needed replaced and or seal. I've cleaned the vent already and still have this problem.
  • 178 Answers
SOURCE: Dryer handle replacement - Kenmore Elite
E-mail me the model number of the dryer and I will be able to find you the information you need. robert_fawbush@yahoo.com
Posted on Apr 09, 2008
SOURCE: Kenmore Elite He3 electrical dryer runs but it does not heat up
odd but it worked for me!! Try resetting the circuit breaker. It will not appear to have blown, this is because only 1/2 the breaker needs resetting, This is much cheaper to try before calling for service or parts. My 2002 E3t has only had this problem once and the resetting worked without further issues for 2 years now. Good luck
Posted on Jan 29, 2009
  • 10865 Answers
SOURCE: Sears Kenmore elite quietheat front loading dryer not drying. Moisture builds up on the window inside.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 28, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: How do I take the front panel off my kenmore elite
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
My kenmore elite dryer model 110 63032102 won't turn on
Check the door switch. Push it by hand and you should hear it click. If no click is heard, replace the door switch with this part.
If the switch is OK, then the only other problem will be with the thermal fuse located on the rear of the machine. Here is a link to that part.
Oct 15, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore H4 not starting
Check the door latch. If the door doesn't latch, the dryer won't start
Oct 03, 2012 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
When we start the dryer it's stsrt making loud noise matal to metal then it goes away for few minutes and comes back
Hi bojanhadziki...
You could have a couple of problems..
1...The door seal may need replacing, making metal to metal contact
2...The drum rollers may need lubrication or replacement
3...The back bearing may need replacement or lubrication.
Please take time to rate me
Sep 26, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore elite refrigerator is not cooling, but the freezer seems to be working fine.
Kenmore Elite refrigerators come in several styles, including units with a freezer at the top and units with freezers at the bottom. The top and bottom of the fridge work on different systems. Sometimes the freezer may function perfectly, while the fridge performs poorly. Most issues with the fridge cooling are due to incorrect settings or poor cleaning practices. Checking common problems with the refrigerator will help you diagnose the situation and keep expensive repairs to a minimum
1. Check that the Kenmore Elite refrigerator is plugged in. Inspect the circuit breaker of the home if the refrigerator is plugged in but not running.
2. Pull the unit out from the wall and vacuum the condenser coils at the back of the unit.
3. Turn the temperature control in the Kenmore Elite refrigerator to the "On" position.
4. Turn up the temperature on the temperature control, located inside the unit on the wall.
5. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the Kenmore Elite fridge door.
6. Check the seal along the door for signs of cracks or dryness. If it is damaged, lift up on the seal to expose the screws that hold it in place. Loosen the screws and pull the seal off. Place a new seal on the unit, starting in the corners and working your way around to insert the tabs into the fridge door.
7. Move food away from the vents inside the Kenmore Elite refrigerator.
I hope i solve you problem.
Have a nice day : )
Sep 04, 2011 | Refrigerators
Freezer builds up with frost about every 60-75 days. have to empty the freezer and allow to thaw for a few hours
I think I can assume the freezer isn't a "frost-free".
A short physics lesson; hot air holds more moisture than cold air; hot air will flow from a warm area to a colder area, and the colder area will cause the moisture to condensate and freeze(if colder area below freezing, as a freezer should be), causing frost build up.The more often the freezer is opened, the more frost will build up.
Now for 3 possibilities:1) If it is a self-defrosting type, check your defrost timer control...not working, or not working often enough.2) Door seals damaged and need replacement.3)Make the kids stay out of freezer.
Mar 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Do I need to secure the tubs inside Kenmore Elite Washer & Dryer?
Not the dryer but you do for the washer ... there is bolts that go in the back to hold the tub ... the bolts came with the washer went it was new... you may be able to get a set from sears...
Oct 03, 2009 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
13 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
