Question about Health & Beauty
Change coil n still misfires on cyl num 6 what can i do next.
    New Friend:
    Problem Solver:
  • 15 Answers
I doubt if acupuncture will solve you coil problem but may help you. Go to the automotive section of this website or google. If each plug has its own coil you can check if its pushed down on plug or you electrical connection to coil could be loose. Check inside d cap or wires and by looking for arcing in a completely dark garage.
Posted on Aug 07, 2013
I rmv plug & coil on #6 cylinder in 08 DTS. When put bk correctly w no damage motor hd vibe, lack of pwr trans wldnt shift smoothly Code = misfire #5 cyl. Put new plug & coil in #6 still bad Help!
Sounds like you have an air measurement issue either a vacuum leak or a out of calibration Mass airflow sensor try disconnecting the electrical connector at the mass airflow sensor with the key off then run the vehicle with the sensor unplugged if you symptoms improve your mass airflow sens is bad if no change get a vacuum gauge on it you should have at least 19" of vacuum at idle if you dont or the needle is bouncing around you have a vacuum leak or bad intake valve also test compression on a known good cylinder like num 1 and num 5
Jun 11, 2015 | Cars & Trucks
2003 infinity g-35 coupe is missfiring
Hi. You may have a wet ignition coil. First you have to locate wet the coil. If you have a check engine light on and a cheap code reader you can check which one is misfiring. Code P0301 means cylinder number 1, P0302 cylinder 2, P0303 cylinder 3, P0304 cyl number 4, P0305 cyl # 5 and P0306 cyl # 6. Looking at the engine compartment at passenger side you will see cylinders 1, 3 and 5 from the front to the back. On driver side you will have cylinders 2, 4 and 6 from the front to the back. I recommend you to purchase a subscription at www.alldatadiy.com to get information about your cars so you can see how to perform a ignition coil removal/install so you can fix your car. If the coil is not wet you can swap the coil position with the coil from the next cylinder, clear the codes and drive the car until the check engine light comes back on. Read the code and if the code change to the cylinder that you put the "defect" coil, replace the defect coil for a new one. If the misfire does not change the cylinder, you may have a bad injector, bad cylinder head valve, bad intake manifold gasket and few other possibilities and for that I recommend you to take to an auto repair shop, because you will need special tools and a deeper diagnostic. I hope that helps. Take care.
Dec 31, 2013 | Vehicle Parts & Accessories
Po300 code multi cyl misfire any sugg
The code you got may not have indicated the correct coil, that was bad
I would put the old coil back in #6 & either walk the new coil to another cylinder, or get professonal help in the form of a scan tool in Mode $06,
if applicable on your vehicle & check for misfires that why
Forget the PO300
Jul 30, 2012 | 2004 Chevrolet TrailBlazer
Random misfire 1997 bmw 528i
remove and clean the injectors
misfires are more injector problems than wires and plugs
Oct 13, 2017 | 1997 BMW 5 Series
2002 toyota tacoma v6 4x4. I had a multipel misfire code and a misfire code on cyl 3&6. I changed the plugs and ignition coil for cyl 3&6. cleared the codes but still having problems with...
I was having the same problem changed plugs, plug wires, coil packs, cat converter and had injectors flushed....cost quite a bit and nothing fixed the problem. Over 1000.00 spent before changing the injectors and this fixed the problem perfect. My truck now runs like new and I hope to get another 185,000 miles out of it......have the injectors checked and use "seafoam"....good luck
Feb 11, 2011 | 2002 Toyota Tacoma
Multiple cyl misfire
please check on compression of all the cylinders. IF there is any valve damage this could cause a fault.Please check this out if your fuel and spark are ok.
Jun 28, 2010 | 2002 Chevrolet Camaro
2006 dodge caravan, 6 cyl. relaced cole, sparkepugs and wires in oct. 2009. Engine is reading #2 cyl. misfire again. Why
Firts time swap spark plug & ignition coil between two different cylinders and read again if the same #2 cyl. misfires !
If #2 cyl. is OK and another cyl. misfires then spark plug or ignition coil is out of order and must be replaced.
If #2 cyl. misfires again then #2 injector must be checked !
If ignition coils & spark plugs (complete set for 6 cyl.) are replaced then you must check #2 injector !
Mar 15, 2010 | 2006 Dodge Caravan
Will not start,code shows misfire on cyl 6 have
The coil pack is most likely the problem for the miss fire on the cylinder,but the engine most of the time will still run,just poorly.Crank shaft sensor would be the next thing to check,if there is fuel pressure present at the fuel rail.Also enough fuel pressure.
Jan 03, 2010 | 2001 Pontiac Grand Am SE
Multiple misfire cyl 3 cyl 6
your vehicle uses a wasted coil pack so two cylinders fail together using that coil so change the coil pack sounds like the favorite to me 3 and 6 are the two cylinders using the same ignition coil
Feb 21, 2018 | Jeep Grand Cherokee Cars & Trucks
Health & Beauty Logo
142 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
