Question about Frigidaire FSC23F7D Side by Side Refrigerator
Dispense Ice dispenser will not shut off I unhooked the wires to the switches that are activated when you push in the Ice and Water levers However it still dispensed Ice when I shut the Freezer Door.
  • Frigidaire Master
  • 2,330 Answers
Http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Refrigerator-Parts/Model-FSC23F7DB1/1428/0165000/R0502012/00007?blt=06&prst=&shdMod=
if you go here this shows you all the parts that are with the dispenser,it sounds like the computer board is bad,maybe the button is stuck in,also there are some micro switches in there that could be bad but without being there it's hard to say what it is,but if as soon as the door switch is closed and the ice dispenser starts it sounds like the touchpad button is stuck or damaged on the dispenser control board part 241708306 and is 38c on the diagram.this part is expensive if you buy it from thr repair clinic and this isn't the part they will take it back for up to 1 year http://www.repairclinic.com/PartDetail/Dispenser-Control-Board/241708306/1196737
like i say without being there i can't just give you a 100 percent guaranty that this is it,there's alot of parts there you might want to call in a tech to be sure of what it is or like i say if you order the part from the repair clinic and it's not the right part they will take it back,also let me ask you if you open the door so no power goes to the dispenser when you push the ice dispenser you should hear a clicking sound,you can try the water dispenser first because that works,if you hear a click when you push in the water dispenser lever but no click with the ice lever it could be the micro switch that's bad.i just repaired one that wouldn't dispense any ice and when i pushed in the lever there wasn't any clicking sound so i knew the micro switch was bad,also you can try unplugging the machine or kill the power at the fuse box if it's easier and leave the power off for like 5 to 10 minutes and see if it resets the board.also when the power is back on you can try pushing on the buttons to see if you can unstick the button but i'd hate to see you just buy the board and it's not the problem,you can also smell the board and look at it for any burn marks and like i say if the board is bad alot of times you can smell an electric smell,hope this helps you out and good luck with your machine
Posted on Jul 19, 2013
ebenezer
  • 25 Answers
SOURCE: frigidaire ice dispenser problem
The ice anger will be controlled by a motor system, the hummming could bea result of stuck rotor or the motor system is faulty. the motor might needs replacement.this will explain why the ice is not dispenced.
Posted on Aug 10, 2007
Tech007
  • 63 Answers
SOURCE: Water dispenser spontaneously erupts when making ice
I had to fix a problem like this the other day you need a inlet solenoid
Posted on Aug 29, 2007
  • 1314 Answers
SOURCE: Ice dispenser
you may have a promblem with your despensor acuator being stuck remove your ice bucket and look in the back of the fridge where the steel rod goes in its like a square hole if you see a plastic bar about half way across it see if you can pull it down while the bucket is out and with the door open hold down the switch the one that dont turn off the light an push the dispessor switch while watching that hole go from crushed to cube and let me know what you see
Posted on Jan 18, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Why is the water running directly into the ice dispenser and running out of the door when we are not pushing the lever to get water?
Sounds like the water valve is stuck or the wiring or switch is defective. As both ice and water are a problem it sounds more like a defective water valve.
Oct 05, 2014 | Whirlpool Refrigerators
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
The water dispenser on my GE fridge, model bss25jsrss, doesn't work. There is water in the lines, and the lights in the front work, but when I try to get water or ice nothing comes out.
There is a simple switch behind the push lever which activates the water/ice dispenser circuit. Sometimes these switches are poorly engineered to the lever with an adhesive or plastic rod which will break away. This is the first place I would look for a culprit.
Sep 25, 2011 | GE Refrigerators
I described the problem poorly, I apologize. The freezer and fridge are at the proper temperature (freezer is at 0, fridge at 40). I've checked and the water flow from the wall into the machine is good...
Hello David ,
Their are a few possible reason the ice is not being dispensed,
1) the door switch is bad...the door must be closed for the ice to dispense and perhaps the switch thinks the door is open
2) the switch that is activated when pushing the lever on the dispenser is bad
3) the dispenser motor is bad
4) the control board is bad
GENE
Sep 23, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Connected water supply and confirmed good water pressure. cannot get water to dispense or icemaker to make ice.
Hi, When you push the water switch in the door, do you the inlet valve humming? Is it possible that the wires came off the inlet valve?
If you remove the inlet valve from the cabinet and unhook the large size tubing that leads to the water dispenser, you can engage the dispenser lever in the door and see if water comes out.
I hope this helps you. Please let me know if I can assist yyou further.
Vic
May 31, 2009 | Refrigerators
Kenmore Refrigerator
check the mirco-switches behind the panel at the dispenser section. basically, when you depress the lever for water or ice, those levers make contact with a switch, and the switch turns on the ice dispenser motor. if the lever is pushed too hard, the switch can be knocked out of position. I had to re-position my ice switch with some duct tape.
Feb 16, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water/Ice Dispenser Mixed Up
Do you have separate levers for Ice and water, or do you have one lever and then you slide a switch to either one and then push the one lever.
Nov 09, 2007 | KitchenAid Superba Architect KSCS25INSS...
No water
MORE LIKELY TO BE BLOCKED OR A KINKED PIPE AT BASE OF DOOR, WHEN YOU ACTIVATE THE VALVE THE WATER FLOWS STRAIGHTOUT OF THE DISPENSOR SO THE MUST BE A PROBLEM IN THE DOOR AREA. REGARDS DVISOR
Aug 24, 2007 | Hotpoint HSS25GFP Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
118 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
