No picture sound ok vs okay va okay no error codes
Model samsung ps42c4501wxxu
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check its main board.
Posted on Jul 20, 2013
2 Suggested Answers
lukster
  • 217 Answers
SOURCE: I have a samsung l42v7 There is no picture. Sound okay
CHECK FOR ANY BACKLIGHTS, SOUNDS LIKE INVERTER BOARD OR POWER SUPPLY
Posted on Dec 30, 2009
Samsung plasma TV sound but no picture
Both Vs and Va voltage should be checked. As far as audio is OK, the possibility of main digital board fault.
Sep 01, 2016 | Samsung Televison & Video
Got sound but no picture on samsung tv model code PN60E530. Help?
Use a flashlight up against the screen to check for picture, if you have a picture, then the inverter is bad.
Jul 12, 2014 | Samsung UN60ES8000 60" 1080p LED 3D TV...
I HAVE A PROBLEM WITH A POWER SUPLY OF SAMSUNG PLASMA PS 51 E530 ALL VOLTAGE IS OK,5VOLT 12 VOLT IS OK,BUT VS AND VA VOLTAGE 0VOLT SO NO SCREEN,I CHECK POWER ON AND VS ON IS OK,can you help me
Sounds like it could be a bad capacitor on the power supply, or possibly on the video out circuit. Bad capacitors are a common problem in Plasma and LCD monitors and T.V.'s.
Jun 25, 2014 | Samsung 51 INCH PS51E530 Full HD Plasma...
Hisense plasma no picture
tv on after class out side coming
Jan 07, 2014 | Televison & Video
NO PICTURE SOUND OKAY VS AND VA OKAY
change the colour wheel its worn u will need a tech to do it
Jul 19, 2013 | Televison & Video
Sound no picture Samsung 58" Plasma TV Model #: PN58C550G1FXZA
if you are a tech in any aspect, try testing the power points Vs and Va voltages. If not present even with the other circuit boards disconnected the Vs is supposed to be 205v when disconnected like on my tv, it only had 12v and the Va which is supposed to read 56v was reading about 10v when the boards were connected (Y Buffers). With the boards disconnected the power supply will read high voltages, and when connected (try lower first, then try upper, then try together). If there is a voltage drop (significant) that particular board connected is the culprit. If the PSU doesn't read a large voltage like mentioned, try replacing the PSU first. Go to www.shopjimmy.com for parts
Nov 26, 2012 | Televison & Video
No picture have sound hp t5064
I have a samsung hp-t5064 with sound and no picture. I purchased a service manual and went through the check list of solving the problem. It tells you to remove 4 plugs from the SMPS board (cn810, cn809, cn808, cn807) and you should get dc voltages at test pin (Vs 207VDC) and test pin (Va 63VDC). If you do not get these voltages at these two pins you should replace the SMPS borad. My question is when all plugs are unpluged I get Vs 0VDC and Va 63VDC but when I start plugging in the plugs one by one nothing changes as far as voltages until I plug in the CN807 Main board and the voltages are at normal Vs207VDC and Va 63VDC. I am asuming the SMPS board is bad. Would I be correct?
Oct 23, 2010 | Samsung HP-T5064 50 in. Plasma HDTV
Dec 30, 2009 | Televison & Video
Samsung HP-T5054 NO pic No sound B
samsung boards are around $200 EACH , usually a bad buffer burns out the Y board , buit yours sounds like a burn power suppy, do a visual of the PS, if looks ok ck for the VA and VS voltages (there is a tag with the values on it) . if the VA or VS is low or missing you will probably need the Y and both Y buffers.
Jul 24, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
