Question about Vacuums
Electrolux 8807 the exclamation light is turning red. I cleaned the brush but the brush does not move automatically and the light stays on.
    Problem Solver:
  • 5 Answers
May need belt
Posted on Jul 22, 2013
dragonsthatk
  • 547 Answers
SOURCE: older electrolux canister brush will not turn used reset button
change the belt
Posted on Feb 12, 2009
  • 8404 Answers
SOURCE: Hi,
Check the end cap bearings ... and replace the belt even though it may not be broken. Put a drop of sewing machine oil (no more) in each end cap bearing.
Posted on May 11, 2010
deme-tri
  • 90 Answers
SOURCE: electrolux vacuum brush not turning
under the vacuum, there is a guard. remove the guard , either by 2 screws or by 2 clips. there is a belt under the guard. that is connected to the brush. the belt need to be replaced.
Posted on Jan 03, 2011
  • 37 Answers
SOURCE: after turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Posted on Feb 06, 2012
askdyson
  • 2572 Answers
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: brush will not stop moving when put in upright or bar floor mode. Also red power light doesn't come on when turned on.
    Hi Chris,
    I'm sorry to hear you're having difficulties with your DC28. I'd encourage you to get in touch with us directly, so we can provide further assistance in resolving this issue. Please call our Helpline free on 1-866-693-9766 - or if you email your contact details to us at askdysonUS@dyson.com, someone will be in touch as soon as possible.
    Best wishes,
    Jack
    Dyson Online Customer Support
    http://www.dyson.com
    My electrolux vacuum has a red light that won't turn off and my brush roll won't work
    Check the belt and the end bearings are free by hand. (electric off plug out) if not free remove plate to access roller/brush, remove clear any obstruction (Hair/string/thread) replace and test. ensure you site belt back on to spindle and roller/brush correctly...
    Aug 22, 2014 | Electrolux Vacuums
    What does yellow exclamation point light mean
    YELLO and RED mean danger - clogging, not brush turning, overheating, .... it is time to RESET -- turn it all off and let it sit for half hour - that is what the manual says, check the brush that is not clogged up and check the inlet to the hose and where the hose goes into the body from the head unit where the brush is - make sure those not clogged either. Turn it on, push the RESET button on left back side of head unit by the switch that changes height. The reset button is like a circuit breaker - stops unit when overheats, starts when reset. Yello is ERROR, and fix it before it turns red and stops all the way. Cheers!!!
    May 31, 2014 | Electrolux EL8807A Precision BrushRoll...
    Red light came on and brush doesnt seemed to be moving
    check your drive belt, its probably broken. your can get new belt everywhere you buy a vacuum and replacing it is usually 2 screws away.
    Apr 10, 2014 | Electrolux Vacuums
    The red "!" icon is on when I turn on my vacuum
    Button on CARPET, lower the handle for use, turn on power and the brush turns. Handle up like for storage, brush does not turn. Bare floor button pushed, does not turn.
    Dec 25, 2013 | Electrolux EL8807A Precision BrushRoll...
    The brush is not turning and a red light is on
    It could be that the brush motor just needs to be reset. You should find a button near the brushroll cleaner step lever.
    Nov 25, 2013 | Electrolux EL8807A Precision Brushroll...
    Red exclamation light is on and brushes not turning
    On my Electrolux Precision, the exclamation light indicates that it detected an obstruction and will stay lit until the obstruction is cleared AND the "reset" button is pushed. The reset button is on the black part (same side as the exclamation light) about half-way back on the side of the vac.
    Apr 17, 2013 | Electrolux Vacuums
    Electrolux Precision vacuum brushes stopped turning and a red light turned on
    there's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
    Jan 12, 2013 | Electrolux Vacuums
    How to replace belt on lux 4000 vacuum?
    The following is for most models of the Aerus Electrolux UR models.
    Lay the vacuum on it's front so you can see the bottom of the powerhead as shown below. Befrore going further, hold your hand straight and move your hand across the opening for the brush. If the bristles don't make good contact, the brush also needs replaced.
    Remove the four screws. Using a flathead screwdriver, place it into the two rectangle openings (shown with red arrows) near the wheels and gently pry on tab to release the top of the power head.
    Flip machine over and gently lift back of cover which will release the front. Lift off and set aside.
    This is what you should see. Remove the two screws at the ends of the brush. Check carefully how the ends of the brush fit in. Gently lift out brush. This is a good time to clean entire interior of the power head. Install new belt over motor shaft and teeth of brush: set brush into place. Insert screws. Check tension of the belt.
    Replace cover of power head, being sure to settle front in just beneath the lip of the front of the base first. Press down until it "clicks" into place. Turn machine over and insert and tighten screws.
    Jan 04, 2011 | Electrolux Vacuums
    Electrolux vacuum brush not turning problem: was vacuuming and rug got caught auto shut off kicked off power to brush. instead of hitting red button to restart brush I disconnected brush to vacuum some...
    Jan 03, 2011 | Vacuums
    I have an Electrolux Genesis model upright. How do I get into it to change the belt?
    rogerpotts_2.jpg Flip machine over and gently lift cover off and set aside.
    rogerpotts_4.jpg This is what you should see. Remove the two screws at the ends of the brush. Check carefully how the ends of the brush fit in. Gently lift out brush. This is a good time to clean entire interior of the power head. Install new belt over motor shaft and teeth of brush: set brush into place. Insert screws. Check tension of the belt.
    Your vacuum is now ready to use.
    Jan 03, 2011 | Electrolux Vacuums
    Vacuums Logo
    57 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
