Question about BrainyTrade 300mbps Wireless-n Wifi Repeater Network Router Range Expander
1921680234 sitecom WLX-2001
Configurazione
I got a problem in connecting my samsung galaxy GT-7500 to sitecom extender 300N .. I have tried to change the IP address but it doesn't work with me . Any help plz?
Which modes are you trying to use this Sitecom? If you have the Sitecom as your Access Point (AP Mode), then you would need a LAN connection to your internet gateway (DSL, Cable Modem, etc). I didn't see any LAN hook up so I assume you are trying to use it as a wireless repeater. So you need to configure the unit differently. The 3rd mode is called Bridge mode. Again, you need to have a LAN hook up to your local network with a router or network switch.
Because your Tablet is connecting to the Sitecom okay, which mean that you either have the Sitecom setting for AP mode or Bridge mode. And the reason it didn't give you access to internet because there is no internet gateway connection to the Sitecom (LAN). I hope this answer your question (or confuse you totally).
Feb 15, 2013 | Computers & Internet
Can someone tell me if the sitecom vp-003 webcam works with windows 7?? it kees telling me driver not found even after i installed it
yes it is, drivers are here http://www.downloadatoz.com/driver/download_87827,sitecom-vp-003-driver.html
Jan 01, 2011 | Sitecom EasyCam VP-003 Webcam
I have lost sitecom installation CD?
Go to this site:
http://www.sitecom.com/support/
enter your module number and you should be able to download drivers from there.
Burn them to a new cd and keep in a safe place.
Jun 03, 2010 | Sitecom (WL -004) Wireless Adapter
Can not access sitecom 300n with factory preset 192.168.0.234 or find trouble shoot in manual
open Network Connectdisable the wlan adapter first. open Network Connections from Control Panel and disable the wlan adapter first.Then Open Properties of the (wired) LocalArea Connection. Scroll down to TCP/IP and Change the Properties: IP=192.168.0.2 and Subnet Mask=255.255.255.0. Then connect the Sitecom using the wire (UTP). You should be able to browse with an internet browser to 192.168.0.234 now. After setting up the Sitecom disconnect the wire and enable the wlan adapter again.
May 15, 2010 | Computers & Internet
Sitecom camera installed and its works good, but doens't work on chatroulette
1st You download Webcam Driver.
Sitecom EasyCam [VP-003] Web Cam Driver
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 21, 2010 | Sitecom EasyCam VP-003 Webcam
Forgotten security key for sitecom
Contact the vendor of the software.
As a "registered" customer, they will issue you a new key.
Jul 17, 2009 | Sitecom (WL -004) Wireless Adapter
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
BrainyTrade 300mbps Wireless-n Wifi Repeater Network Router Range Expander Logo
121 people viewed this question
Top BrainyTrade Computers & Internet Experts
David Payne
David Payne
Are you a BrainyTrade Computer and Internet Expert? Answer questions, earn points and help others
