Question about Timex T5G811 Marathon Stopwatch
Battery replacement What kind battery its use?
What type/kind of battery do i use to replace in my super hero ii ss black nixon watch
Take your Nixon watch to a jeweler to have the battery replaced.
Apr 24, 2017 | Nixon Watches
Cl 7320. What type of battery does it use?
sadly if we could see it and read the numbers off the back we would know .
Nov 08, 2015 | Watches
Casio g-shock protection model blank face after new battery installed by a jeweler
What kind of battery did they put in it?? G shocks are powered by a rechargeable solar battery!!! Should not have been replaced unless it was the same type of battery. I would be going back to jeweler and asking them to send your watch to Casio and they pay for the new solar battery. Let me know what happens.
Aug 19, 2010 | Casio G-Shock 800D 7V watch
What kind of battery does the watch need?
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 20, 2010 | Field and Stream F13PKTPK Pocketwatch
Battery replacement
Not sure where you are located, but just take your watch to the jewelry counter at Walmart and they will do it for you. Battery about $8
Jan 12, 2010 | Philip Stein Teslar Small Case Diamond...
Two weeks after buying the watch it just stopped the jeweler thinks it might be that the second hand is getting stuck
Depends on the kind of watch. If it is a quartz watch it could be the battery.
If it is a mechanical it has a more serious problem. A new watch most likely will not have a problem with a hand touching unless the watch has taken a great fall and the hands are jarred enough to misplace them. Of course this kind of fall will cause other damage.
Seriously, most jewelers don't know what a watch is let alone how it works or what could be wrong with it. Have a watchmaker look at it and they can give you real information.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Watches
New fossil watch
It is not likely that there is a protective cover over the battery itself, if there is anything on it to prevent use while not owned it is a little pc of plastic holding the stem out. It is sad to say but there is no way to tell how long the watch had the current battery in it before you received it. It is common to get a new watch and have the battery die shortly after or be already dead. Go to a local jewelry store to have replaced, make sure they are able to test the old one FIRST, if the battery is dead, allow them to replace it, if the battery is fine, return the watch to Amazon.
Dec 05, 2007 | Watches
Timex T5G811 Marathon Stopwatch Logo
37 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
