Question about Dometic Refrigerators
Dometic fridge code eo how to repair - Dometic Refrigerators
I have a dometic fridge freezer model number RM2652 where can I get it repaired on the recall. I live in the Uk
go google and type in --authorized repair agents for dometic fridge /freezer equipment---
look for one close to where you are
contact the "contact us " area on the manufacturers web site
Sep 17, 2016 | Dometic Refrigerators
I have a dometic fridge that will not work on 120 or propane. all fuses are good. No lights inside fridge or on outside.
possible there is a restriction in the system. to repair turn fridge around and it should sit on the top for 24 hours. next step turn to normal position ,make sure it is leveled and check
May 21, 2014 | Dometic RM2652 Refrigerator
Does not turn on
make sure at least 12 volts at board if not display will not light
Feb 26, 2013 | Dometic RM1350WIM Elite 22 Fridge...
RM2401 Dometic propane fridge
Would you like a service manual and my help for free?
Let me know, Sea Breeze
appliancepartsoutheast@live.com
Aug 08, 2009 | Dometic WA3210 Compact Refrigerator
Just bought a 1999 camer and we cant get fridge to turn on
If you like I will help you repair your Dometic Model Number RM2852 or click on HERE=> ALL THE ANSWERS FOR DOMETIC CAN BE FOUND BY CLICKING HERE
Thanks, Sea Breeze
Jul 11, 2009 | Dometic RM2852 Refrigerator
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
My Dometic trailer refridgerator is warm but freezer is freezing.
Brandi4723,
Unfortunately, you have a bad cooling unit in your refrigerator. Then ammonia smell means that you have a leak in the unit. TURN THE FRIDGE OFF!!! Do not use the fridge on AC or Gas until you have the cooling unit replaced or buy a new fridge. Depending on the model number and serial number of the fridge, it may be under recall by dometic and you might be able to have it repaired for free. If you will provide me with the model number, serial number and the serial number of the cooling unit (found on the outside of the unit in the fridge compartment, lower tank of cooling unit), I can then tell you the pricing of the repairs or whether it is under recall.
Again, TURN THE FRIDGE OFF and do not use it...RISK OF FIRE!!!!
Hope this helps,
Jeff
Jul 03, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
225 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
