Airco furnace I need the wiring diagram for a 20 year old Airco furnace, Model AHBS-150. Someone pulled out all wires as a quick response following the recent flood.
4 Suggested Answers
SOURCE: I have a 20 year old furnace the transformer went
The transformer is for the low voltage side of your furnace, you should be able to take the door off of the furnace and follow the wiring schematic on the inside of the door to wire it back correctly.
Posted on Sep 30, 2009
  • 2463 Answers
SOURCE: Combustion Chamber hot air oil furnace
it is down to cost how old is it , is it worth it over the cost of a new heater you will neede to speak with a plumber to see what is best to do with this heater as they can look at the heater and advice you .
Posted on Jan 29, 2010
woobie dog
  • 1273 Answers
SOURCE: I'm looking to buy motor for an Airco Gas furnace
Hi, W/D here.
Make the necessary sketches, showing what color wire goes to which terminal (trust me on this, it's a really good idea). I do it whenever two or more wires are involved, and I've been known to also lable terminals with the wire color with a "Sharpie". Remove the motor and start capacitor. Take both with you to your local appliance parts supply house. They will match you up with a similar motor, and match the capacitor to the new motor. Getting the exact motor you described isn't important. Getting a good quality replacement motor with your horsepower rating, shaft size and matched capacitor is. They'll have it, and the cost will be less than running one down. I installed a replacement in a furnace last week, with the motor, capacitor and a pack of crimp-on terminals (I ran out!) costing about $109.00. Your's may be less at 1/6 hp. The one I installed was 1/3 hp, replaced a GE, and works fine.
Best regards, --W/D--
Posted on Feb 19, 2011
Why is my airco not cooling?
I believe that error code refers to a defective Indoor Coil Temperature Sensor (Thermistor); probably an "open" or "shorted" condition.
Jul 08, 2014 | Heating & Cooling
Manual for Arctic Cool Air Conditioner Model #AP-08CR1FACS
hi there...I am MiLi,
I've a question about this, because I've a similar problem.
My airco is displaying this code E2, and I'm wondering what it means.
I don't have the manual anymore to look it up. And the Airco stopped cooling, it is blowing warm or house temperature air.
It is set to cool, but blows warm air.
Is there someone who can help me out with this?
I just want to know what this code E2 means and what to do about it.
MiLi
May 26, 2012 | Danby Heating & Cooling
The airco system has completely stop working. The 4 position switch only work on number 4 and bring outside air (not airco) into the cabine
check fuses first - if ok.
check for refrigerant in A/C - if ok.
check switch and wires - it may be bad.
Apr 14, 2011 | 2001 Jeep Cherokee
I'm looking to buy motor for an Airco Gas furnace model ACF-45, serial #DI-109. The motor is Tamper, 1/6hp, 1727rmp, type S-100336. Do you have any suggestion?
Hi, W/D here.
Feb 19, 2011 | Dayton Gas Furnace Heater
Dear sir i have an A12AW1 art cool when i use the airco in the winter outsite temp -10 °C the airco somethime stops althow the roomtemperature is not reached. The airco is also outside...
Not sure the specs of 134. But, at 20 to 30 degrees Fahrenheit your heat pump is not going to be working very efficiently. Now, the ice on the coil is another story. Possibly your defrost is not working BUT, you don't have backup heat anyways. Yes, you should have a low pressure error code, I don't think it's a refrigerant issue.
May 26, 2017 | LG Heating & Cooling
Jan 29, 2010 | Heating & Cooling
I have a 20 year old furnace the transformer went took it off a year ago forgot the wiring , need a wiring diagram
Sep 30, 2009 | Heating & Cooling
I have a Westpoint split A/C Model WSC-09. The unit turns on but the fan (the indoor side that blows cold air) does not operate.
Most likely a broken fan capacitor.
When you follow the wires from the fan you will find it. Try to replace it. (electronical store)
I'm an airco service engineer, in 95% of the cases this is the cause.
Frans Verhees
The Netherlands
Sep 14, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
