Question about Kenmore White Electric Stove
C970 kenmore stove- right side outlet is not working. How do I get it in use?
C970-656933 Serial # NFO1713653. A technician is here. The right reciprical is not working. Can you help us?
What year is model#C970-648229 serial #Nf84616121
ring a service dealer / agent for the information as they have it on a data base
Feb 25, 2016 | Kenmore White Electric Stove
How do I clean under the electric elements on my basic westinghouse stove
Hello friend, thanks for your post!
I understand that you would like to clean under the cooktop on your Frigidaire range. Could you provide me with your model number please? You can locate the serial tag (which lists your model number) on the storage drawer on the right hand side. With this information I can better assist you. -Matt
Sep 16, 2014 | Electrolux White Westinghouse Stove Range...
VF72824070
Hello Anonymous, that's a great question!
In order to provide you the correct cleaning instructions for your Frigidaire range, I would need your model number please. The serial tag, which lists your model number, is normally located in the storage drawer, on the right side. Thank you and I look forward to hearing from you. - Z
Aug 30, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
Older kenmore electric stove
You could try to restart and stop clean cycle. Otherwise unplug stove and remove back panel to access locking mechanism.
Jun 24, 2014 | Kenmore White Electric Stove
Model # 79094320300 the clock and oven does not work on my Kenmove flattop stove, what can I do about it?
The clock runs on 110 volts and the oven at 220 volts. If the cook top is on, the issue is in the stove. Best left to a qualified technician.
If the cooktop is also not functioning, check the breaker.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
Frigidaire stove oven want come on model # FGF368GSJ
Hello Larry D Harris - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Do the maintop burners work? Granting that it does, you can try confirming that the shut-off valve on the gas pressure regulator is in the "ON" position (usually located on the back left-hand side of the range). This valve shuts off gas to the oven. If after the basic troubleshooting, you continue to experience the issue I would suggest contacting a certified technician to assist in the full diagnosis and repair of your range.
Nov 06, 2012 | Frigidaire Stove/Oven/Range Cooktop -...
I do not get a tic..tic spark when I turn on the stove. No problem with the outlet either.
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Oct 08, 2010 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Kenmore White Electric Stove Logo
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
