Connect dvd player element tv
The dvd player is built in to the TV. It only runs for about 20 minutes then make a funny noise, stops playing and screen goes blank. It goes back on after being turned off but then does the same thing after about 30 seconds. Can I plug another dvd player into the TV?
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Yes if the set has a set of audio/video jacks(a rear or side input) and that would be cheaper than fixing the player in the set.
Posted on Jul 20, 2013
  • 142 Answers
SOURCE: dvd player
SOME dvd players have a small hole in the front... just large enough for an opened up paper clip to fit into. If yours has this, unplug your machine and insert an unfolded paper clip into this hole and gently press the mechanical eject switch. If you don't have this feature, your only hope is to disassemble the bottom of your set and spin the eject motor by hand to remove your disk.
Posted on Mar 10, 2008
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
Shuttle83
  • 1139 Answers
SOURCE: samsung plasma ppm42s3 , picture wobbling,sometimes screen goes blank
Hello arunaik_6,
This looks as if a component has become thermally sensitive. The best way to find this is to use component cooling spray. It looks as if the problem is localized to the tuner section. Take the back off of the TV and turn the TV on, wait until the problem occurs and lightly spray the tuner section with the component cooling spray watch for any reaction, then if this does not work spray the Microprocessor and the LVDS section and watch for a reaction. The set should go back to normal when it does that section is the problem, try to localize the problem to one component. Then replace that component.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 16, 2008
stonephoenix
  • 563 Answers
SOURCE: My Sony KDF-E60A20 loses audio and video in a cyclical manner
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher. You should call the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 07, 2009
  • 8457 Answers
SOURCE: screen goes blank but come back when TV is turned off and back on
Ur tv LCD inverter board it dead.Replaced this LCD inverter board ur tv picture will return.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 14, 2010
Hi I have a Bauhn DVD TV from Aldi approx 1 year old. It's played DVDs great until I watched a movie on a USB. Now it won't recognise the DVDs and shoots them out after making a clicking noise. Sorry...
Hmm... I think there are many possible answers to this.
- Try to select DVD manually.
- Try to add a DVD while your USB stick is attached.
- Try to pull the wall power cable. Wait for 20 minutes, then plug it in and start the DVD player.
Very strange... Do you have a guarantee?
Jul 19, 2014 | Televison & Video
Run the signal from a AKIA DVD Lcd TV to a Projector Screen TV
from the back of the tv player it will connect to the projector on the big screen usig rca leads
Jul 30, 2008 | Akai CFTD2011 20 in. EDTV-Ready LCD...
My Element TV is hooked up to the Dish Network. I have a dvd hooked up to the TV also. What do I have to do to watch the dvd on the tv
To watch a DVD your player needs to be connected to the TV using a scart or RCA connectors (red, yellow and white) depending on the type of connections available to you. The easiest way to connect the DVD player to a television is via Audio/Video connections that are usually supplied with it.
Next plug in your DVD player and power it up.
Next use your remote to select AV 1, 2 or 3 or HDMI - depending on the input you used at the back of your TV. Insert DVD and play! For example, if the DVD player is connected to the SCART socket labeled Av1, then you need to select Av1 with the remote.
The use of your DVD player is not dependant on the dish receiver - it works on a serarate input direct to the TV. Connecting your DVD player in this manner direct to your TV will not affect your cable or antenna connection to your television.
Thanks for using FixYa. Please remember to leave a vote for the solution.
Sep 07, 2011 | Element Electronics FLX2211B 22 in. LCD TV
Annoying sound from the DVD player that won't stop.
That is normal for DVD/TV's the dvd is setting it self only takes about 15-20 sec. If still making noise after this problem with dvd
Nov 07, 2009 | Polaroid TDX-02610B LCD TV
Tv built-in dvd player wont play thru surround sound
goto your menue setings and slect sround sound and set up to external sound system.
Jan 10, 2009 | Toshiba LCDTV/DVD Player 19HLV87
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Dec 20, 2008 | Yamaha HTR-5930 Receiver
T.V. shuts off when I try to play a DVD in the built-in player
Try putting in a VCR tape let it load and hit stop. If the set stays on it's the VCR deck causing the problem. It will be either be bad sensors or LED or possibly the mode switch. Let me know if this helps.
Oct 15, 2008 | Philips Magnavox 27MS343S 27" TV
Memorex 32'' LCD TV/DVD combo, DVD will not play
funny how **** happens....mine turns on and says memorex then stays on with no picture or sound.
Aug 10, 2008 | Televison & Video
DVD not working!
sound like the lazer drive unit is faulty.
Expensive to fix.
My suggestin is by a new one.
Dec 13, 2007 | RCA 20F610TD TruFlat TV/DVD
Televison & Video Logo
312 people viewed this question
Top Televison & Video Experts
Electro Med Services...
