Question about Air Tools & Compressors
Does the husky 3650 have a fuse on it because the motor runs great but im not getting power.
  • 17,155 Answers
No, there is no fuse. The problem is most likely the capacitor. Do you have the model number on the motor
Posted on Jul 21, 2013
What kind of oil?
It actually depends on the environment but you will be okay with 10W30
Mar 27, 2016 | Husky 3650 Watt Generator with Subaru...
Husky 5000 watt generator quit producing power.
You could have a bad circuit breaker button. Replace that and see what happens.
Dec 24, 2015 | Husky Electrical Supplies
Won't generate power
Need to replace the brushes on the dynamo and have the wire coil checked for shorts. Take to an expert to have the coil checked/ varnished.
Jun 24, 2014 | Husky 3650 Watt Generator with Subaru...
I have a Husky 1850 watt generator with a Subaru motor. The motor runs great but will not produce AC. It was working fine then suddenly the lights went out in my garage. I replaced the diode but did not...
A couple of things would be worth checking into. Of course, I'd pretend that you checked the output fuse or circuit breaker? If you can check for voltage directly from the stator or armature and check the results. Nothing? If it has them, could be brushes. Also, if it's a fuse, don't just do a visual...check it with a test light or multi-tester of some sort.
Jun 12, 2014 | Electrical Supplies
3650 generator won't start!!
I assume that the spark plug are good and the gas line is clear. Try to adjust the gas line supply and default engine startup revolution settings try it full half and minimum back and forth it works. Other gen sets requires a mix of oil with its gas, please do it when it is required with exact proportion. Hope this helps. Goodluck.
Mar 18, 2014 | Husky 3650 Watt Generator with Subaru...
I have a sym husky 125 2000. I can't find my fuse
It is usually next to the battery or in the head light.
Jun 20, 2013 | Motorcycles
No power, it is plugged in
HP Deskjet F4480 All-in-One Printer, Scanner, Copier is the best printer
Jun 13, 2010 | HP DeskJet 3650 InkJet Printer
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
Jan 18, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
