Question about Irons
Which color wire to connect wherein Philips Steam Iron GC 1115?
    Top Expert:
  • Irons Master
  • 12,223 Answers
See the diagram attached. Remember the input will be 120Vac, and NOT 220Vac.Normally the red vs red, blue vs blue, black vs black, white vs white. DO NOT alter any color with another colorWhich color wire to connect wherein Philips Steam - 20888821-2e6c-4061-81a5-271734ea16ee.jpg
God bless you
Posted on Jul 20, 2013
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
  • 5 Answers
SOURCE: Yamata Steam iron 8800
Order Part Number 5 from Yamata at 305-418-4421
Yamata.com
Also see the parts diagram I just attached.
Posted on Jul 13, 2009
  • 3741 Answers
SOURCE: Iam attempting to fit a new dual cord to my steam
The Dual Kilowatt Switch MUST be set to the proper kilowatt rating in accordance and Connect incoming power to floating black pigtail leads labeled "L1" and "L2. keep updated,
Posted on Dec 24, 2009
SOURCE: Steam iron is not heating.
Yes you most likely can, they are very simply consisting basically of, a switch, a thermal fuse, a thermostat, and an element.. all wired into the Phase wire, the neutral, is simply the return. Take it apart and draw a diagram of how it all goes together and reverse the procedure.
Posted on May 09, 2010
EwingElect
  • 276 Answers
SOURCE: I need a manual for a philips pressurised steam generator iron
Check out the bottom of this page for the User Manual:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=GC8320/02&scy=GB&slg=en
Posted on May 26, 2010
I purchased the Philips GC 7000 I want to know if the temperature can be adjusted
Because its a temperature controlled iron, I would say that it only gets to the temperature to create steam and no hotter.
Apr 26, 2017 | Philips Irons
Not steaming
Steam Iron Not Working ' ThriftyFun
www.thriftyfun.com/Steam-Iron-Not-Working-1.html
Sep 4, 2013 - Here are questions related to Steam Iron Not Working. ... Why is my mini steam iron not working, after reaching 20 pounds of pressure? How do ...
My iron does not produce any steam - Philips
https://www.philips.co.uk/e/.../iron-does-not-produce-steam.html
PhilipsThe steam control may have been set to zero steam position. 2. There is no water in the tank and/ or the settings are not set correctly. 3. The steam vents of the ...
GC1015/31 Philips Steam iron GC1015 - Philips Support
Nov 18, 2015 | Irons
Refill water tank light won't go out
Then replace it because they are not repaired.
Jun 30, 2017 | Philips GC 8220 Iron
Philips GC 8220 repair manual
Red water light has come on for the first time.
water chamber is full of water.
Iron is not producing any steam what could be the problem ?
Sep 14, 2012 | Philips GC 8220 Iron
I need to descale my iron and don't have any instruction manual.
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Apr 03, 2011 | Philips GC 2522 Iron
How to clean a phillips gc 8320 steam iron
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hi,<br />Here is a tip that will help you with that problem...<br /><br />Cleaning a Steam Iron Soleplate</span></div> <div class="solution-text"><span><br /><a href="http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate" target="_blank">http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate</a></span></div><span> <div class="solution-text"><br />Cleaning a Steam Iron White Scale and Brown Water</div> <div class="solution-text"></span> </div> <div class="solution-text"><span><a href="http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown">http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown</a><br />heatman101</span> </div><!-- /solution text --><!-- helpful bar -->
Aug 26, 2010 | Philips Irons
Cleaning Carezza soleplate of iron
Here is a tip that will help you with cleaning the sole plate of your iron...
heatman101
Jul 06, 2010 | Philips GC 8220 Iron
Iron producing lots of water
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 18, 2010 | Philips GC 8220 Iron
Irons Logo
170 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
