Question about Philips Audio Players & Recorders
Replacement speaker wire surround sound
My dog chewed through a wire connected to a speaker for my philips surround sound. Wondering where I could buy a replacement wire that has right connecting thingy on the end?
    Genius:
  • Philips Master
  • 1,054 Answers
Philips part is going to be hard to find. Can you splice in a piece of regular speaker wire? Just make sure the wires don't touch each other or you can short out the amp.
Posted on Jul 19, 2013
Testimonial: "Hmmm, good idea. I suppose I could cut off the frayed ends of the existing wire and try splicing them together, although it's a very thin wire. Thanks!"
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
SOURCE: All my speakers don't work.
Did you press the "TEST" button on the remote? It will send some white noise to each speaker that is hooked up, one at a time.
Posted on Jan 05, 2009
SOURCE: No sound from surround speakers or rear speaker
is there a switch in the back for surround on/off
Posted on Apr 14, 2009
SOURCE: Center and surround speakers work, but front right and front left speakers do not put out any sound
I had the same problem. Set the reciever on 6 channel stereo. On this setting, you should be getting the same sound out of each speaker. Isolate which speakers aren't getting sound. Now, on your speaker switch (the A/B button), select A. If that doesn't fix it, select B. If that doesn't fix it, try A and B (if you can on your reciever).
Now, when you switch back to pro-logic, make sure your a/b channel switch is in the position that worked in 6 channel stereo. Yamaha recievers have a memory, and when you switch various modes, it makes auto adjustments based on what you had set in the past.
Hope this helps
Posted on Apr 19, 2009
Replace bad wires
Unlikely to be bad wires unless the cat, dog or rodents have chewed through them?
The obvious thing is that as wire has come unplugged.
I have been through a number of sets of computer speakers. I now have a pair of Bowers and Wilkins MM1s. The sound is amazing and they are actually repairable and have great warranty.
http://www.bowers-wilkins.net/Speakers/Computer-Speakers/MM-1/products-details.html
Mar 23, 2014 | Harman Kardon HK206 Computer Speakers
I was whatching my daughters dog while she was away on business at my home. some how some way he managed to chew off the yellow connector plug for the speaker and chewed it up beyound use, as well as chew...
I was able to catch a glimpse of the back of this unit. I cannot tell by the picture but it is either a RJ11 connector or RJ45 Connector. RJ 11 is the connector on your landline phones and RJ45 connectors are used in computer networking applications. If you have either of these cable laying around you can verify which is which, after that if you do not want to buy the crimp tool for these connectors I would suggest sacrifice whichever cable it ends up being (RJ11 or RJ45) and splice your speaker wire to the two active leads, + and -. Good luck!
Jul 19, 2011 | Durabrand STS98RW Theater System
My dog chewed the cord at the plug and the plug is ruined
There one of two ways you can fix it, go to a hardware store or Radio Shack to buy a replacement plug "strip wire and screw into plug" or have a tv technician hard wire a proper cord with a plug end in the set "best solution"
Jan 27, 2011 | Philips Televison & Video
My dog chewed through the cable of my Philips shp2500 headphones, I have reconnected the all the wires but they still don't work. any help guys?
Feed the dog some good food next time...you might need to solder the wires and make sure the ground is not cross wired to any signal wires.
Dec 08, 2010 | Philips (33-01-031) Headphones
Replacement remote
Required Aiwa remote is available in Part Store for $39
Thanks.
Nov 21, 2009 | Aiwa AV-D58 Receiver
Dog chewed the plug on the speaker wire. Need replacement.
I have the Philipts HTS6500 speakers (2 speakers and 1 subwoofer) packed in a box in my garage. I will sell to you for $50 (used condition of course- but no scratches or cracks in the speakers). perfectly working condition. calvinmo@hotmail.com
Oct 17, 2009 | Philips HTS-6500/37 System
My rear centre speaker wont stop crackling really loud constantly when the surround sound is on, any idea's why this would be happening??
It's a short or a loose connection. Check where it hooks up to the surround system or sub. depending on what kind you have. Or you might have a mouse chewed it or a staple through it check the wire run for issues.
Mar 14, 2009 | Philips Cineos HTS9800W System
Nintendo ds lite charger
just buy a new one i use 3rd and 1st party work the same keep it away from your dog
Jan 15, 2009 | Nintendo DS Lite Console
My mom just bought this philips sound system and the subwoofer is not producing any sound. The other speakers work just fine but the sub woofer does not work. I was wondering if their was any call backs or...
Press the surround button on the Philips remote to see if the subwoofer will begin producing noise - the surround button switches the mode from simple stereo to full surround. I would test the surround button while watching a DVD, because not every tv channel is going to even produce surround effects. Good luck!
-Tha Mp3 Doctor
Dec 18, 2008 | Philips HTS3450 System
78 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
