Question about Omnitech 10-Sheet Micro-Cut Shredder
Omnitech only runs in reverse
As soon as I press power the shredder starts, but only in reverse. If I press forward nothing happens. It wants to run continuously in reverse. Help!
  • 221 Answers
In the middle of feed opening there is a sensor which in your case will be stuck. Try clear it using tweezers. Failing that soak the blockage up excessively with WD-40 as it will loosen and soften stuck paper leave it for 10-15 minutes, repeat 2-3 times. Then power on the unit and it should be good as new! Good luck
Posted on Nov 03, 2013
Testimonial: "Thanks so much, but unfortunately I gave up after two months and got rid of the shredder. I would have totally tried this out. :-("
How do you removed jam paper in the schredder
1) pull what you can of the jammed paper out. Make sure the shredder is unplugged whenever trying to work on or in the unit.
2) Then liberally soak the remaining jam with shredder oil and let it sit for 15-20minutes.
3) Try to pull out what you can again. Use tweezers or pliers if available.
4) Then first start the shredder in reverse and then alternate for a few seconds between forward and reverse.
5) If it is still jammed repeat all of the steps as necessary.
Mar 09, 2015 | Omnitech 10-Sheet Micro-Cut Shredder
Why does my shredder run when there is no paper, but stops as soon as I insert paper into the slot?!
You may have paper stuck in the blades and its jamming.try forward and reverse to free it up or you may have the head unit on the can faced the wrong way. Pull it out and turn head around and than try. I know on some shredders if the head unit does not fit on the right way it wount push down the safety switch and it wount run.
Mar 02, 2015 | Omnitech 10-Sheet Micro-Cut Shredder
My shredder says it will shred cd's and dvd's but when I tried, a cd went in 1/2 way and now is stuck. Motor runs but nothing happens in forward or reverse
You can turn the shredder over (after unplugging the power cord) and see if you can pull the pieces out from under side.
Sometimes the motor gear teeth break off, and the motor just spins but wont go forward or reverse.
Hope this helps.
Feb 25, 2015 | Shredder Office Equipment & Supplies
What model or industry part number of ir sensor do i search for to fix my Omnitech paper shredder? It's a model:OT-EXC10A
What you see with one sensor dark and one sensor clear is correct. Try cleaning the sensors with a cotton swab and a touch of rubbing alcohol. Chances are the sensor is dirty or may have a scratch on it. If cleaning doesn't help then replacing the sensors is your next step.
Feb 25, 2015 | Office Equipment & Supplies
What is the website of the omnitech company ?
Isn't that the one that FatWallet.com was saying Staples was selling for $20 with free shipping?
Omnitech 10 Sheet Cross Cut Shredder 19 99
Anyway, If you look on the UL label, there should be a phone number to call. (If yours doesn't have it, call 800-675-4481.)
Someone on Amazon had one where the green light came on, but nothing happened. The tech told him the sensor had to be reinitialized. Told him to turn it off, put in a thick paper (birthday card thickness) and turn it back on. He wrote that it worked and runs fine now. (But he still is not happy with it.)
Aug 25, 2014 | Omnitech 10-Sheet Micro-Cut Shredder
Shredder keeps running on auto
Unplug it and check to see if theree is any paper caught in the Start switch. Turn it Off, plug it back in and start in the Reverse mode. Then turn it Off and set the swich for On - shread.
If that doesn't work unplug it and find the start switch trip wire, Toggle it a few times with something thin - don't push too hard. You can also spray the switch the canned air used to clean keyboards. Plug it back n, start it in reverse then move it to shread.
Jun 19, 2014 | Omnitech 18-Sheet Cross-Cut Shredder
My shredder runs non stop, when I insert paper to shred , it stops... I push reverse, it works , pull paper out and runs non stop.......
Sounds like a bad or stuck sensor, acting as if it is always seeing a peice of paper in it. Check if you can find it and maybe it is just stuck to the on position..
Nov 07, 2013 | Omnitech 10-Sheet Micro-Cut Shredder
Is there a sensor for Omnitech shredder OT-NXC18PA? if so where can I locate it?
I have this same shredder and same thing happened to mine just 2 months after warranty is up. I called the company and told the sensor is gone and there is no way to replace. BTW mine runs in reverse but not forward.
Jun 24, 2012 | Tech Solution Office Equipment & Supplies
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Omnitech 10-Sheet Micro-Cut Shredder Logo
418 people viewed this question
Top Omnitech Office Equipment & Supplies Experts
ray gallant
Are you an Omnitech Office Equipment and Supply Expert? Answer questions, earn points and help others
