Question about Sharp Cv-p12lx 11500 Btu Portable Air Conditioner Ac
Air conditioner shudders, stops blowing cold, then resets every 5 mins
1) The air conditioner starts just fine, blowing cold. 2) Then, about a minute later, it shudders loudly and shakes, the cold air stops 3) There is a short period (15 sec) of loud, high fan blasting 4) Then it is no longer blowing cold, just fan, for 5 minutes or so 5) Then the cold kicks in again, and the cycle repeats. Needless to say, 1m cold out of 5 isn't doing much to cool the room. I have checked, and cleaned, all filters. I know this model of air conditioner has an internal reset to turn off the condenser, so it must be getting triggered. Can anyone guess what would cause it to shudder all of a sudden and trigger the condenser shutdown??? Thanks!
  • 3 Answers
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Posted on Jul 19, 2013
2 Suggested Answers
  • 11800 Answers
SOURCE: sharp AF-M808X air conditioner. suddenly
Simple test: the thermostat in your unit is electromechanical - unplug the unit from the mains, take it out and measure the resistance between the 2 electrical contacts, if it doesn't goes to near 0 when you turn it even a little bit then it's defective and it will have to be replaced.
If the resistance does indeed goes to near 0 then the defect is in the AC system. Another simple test: open the casing of the unit and put your hand directly on the compressor; now turn the thermostat button. If it doesn't vibrate then the starting capacitor of the compressor has failed and it will have to be replaced with a similar one.If it vibrates then the cooling circuit has got a leak and all the fluid has been lost. For that you will have to call a pro that will solder the leak shut and refill the circuit with the appropriate fluid - only he will have it, it's not sold on the customer market.
Posted on Jul 22, 2011
How do i get my newair af 1200e portable air conditioner to stop blowing cold and warm air.
that is normal operation when thermostat setting is reached it will cycle off compressor.
Sep 09, 2015 | NewAir Heating & Cooling
15,000 btu roof mount 2nd ac nonducted cycles about every 5 or so mins ice cold air for about 1 mins
Have you checked location of probe for return air? Remove filters and find probe to make sure it is about in the middle of flow of return air. Let me know what you find.
Jan 12, 2013 | Dometic Rooftop RV Air Conditioner
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
Fan cutting on and off every 5 mins
The only thing that is going to but the fan off is the thermostat. When the fan stops, immediately check the thermostat on the wall. See is there is power between the B terminal and the GH terminal. If none, then replace the thermostat. If there is, then replace the control board in the AC. That means that the fan relay on the printed circuit board is weak.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
After 1 min,it signals and blow the cold air.
sound like a high limit problem check any filters
May 07, 2009 | Heating & Cooling
Weather king central air conditioner
You have done a good job under the circumstances. It could be a bad start/run capacitor as well. It carries a lot of amperage so I suggest hiring a technician to check the capacitor and the motor.
Jun 25, 2008 | Heating & Cooling
Sharp Cv-p12lx 11500 Btu Portable Air Conditioner Ac Logo
346 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
