Question about Dryers
Wm3431hw How do I install the replacement handle? I cannot seem to figure out how to get tension on the spring so the latch is flopping back and forth.
    Problem Solver:
  • 13 Answers
I woild hold the handle in one hand andput the spring on wear its to be the spring has to have tensionbefor it willwork i donot know what handle lookslike i know its going to be hard to work out but keep trying
Posted on Jul 19, 2013
Door will not stay shut
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can download Whirlpool owner's manuals, installation manuals, and parts lists here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Jan 19, 2014 | Maytag MMV5165 Microwave Oven
Door does not stay closed
The service manual for the R-408LS (the model you posted it under) is here.
You can order parts from the Sears Parts Direct Web site.
Oct 26, 2013 | Sharp R408LS Stainless Steel 1100 Watts...
The latch spring brole on the door, it will not lacth and stay shut. How do I get inside the door to install the new spring? And can I get a free service manual online? Thank you, Jan Frey
You can order these Electrolux (by Sharp) parts from Encompass here or you can call them toll-free at 866-779-5835.
One or more of these service manuals should work for you.
http://www.microwavedisplay.com/BLMV169_GLMV169_PLMVZ169GCB_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
Sep 17, 2011 | Frigidaire GLMV169 Microwave Oven
Install door latch cable
Technical Instructions
See picture below
1. Remove door trim panel and water shield per
NOTE: Place a strip of masking tape along the edge of door before removing trim panel to prevent scratching the door with the trim panel removal tool.
2. Snap cable housing end from slot on inside door handle assembly and disconnect cable.
NOTE: Use care to prevent bending of cable housing retainer bracket.
3. Remove rear window channel retaining bolt to allow access to door latch.
4. Position a block (screwdriver handle) between the latch and the door inner panel and snap the cable housing end out of slot (towards inner panel) on door latch assembly and disconnect cable at latch.
NOTE: Use care when removing cable housing to avoid bending of the latch. Discard cable.
5. Hook up new cable at latch and snap cable housing end into slot.
NOTE: Make sure the cable housing is fully seated in the slot.
6. Apply a light film of Teflon grease to the barrel end of the cable. See Figure A.
7. Install return spring. See Figure A.
NOTE: Ensure that the push button rod is located between the spring and the door inner panel.
8. Install foam block at latch. See Figure A.
9. Position water shield over the return spring and install push pin to retain upper portion of water shield. See Figure B.
NOTE: Push pin goes in the same hole as the return spring.
10. Clean hands of grease before performing step 11.
11. Remove protective backing along the lower edges only of the water shield. See Figure A.
12. Install latch water shield at door latch. Pinch the exposed adhesive surfaces together to secure the water shield. Check to insure water shield is not showing through the door shut-face latch access hole. See Figure B.
13. Attach cable to inside door handle assembly and snap cable housing into slot.
NOTE: Make sure the cable housing is fully seated.
14. Check the gap as shown in remote control using a 3/16 drill bit shank end. The drill bit shank should fit in the gap without any clearance and a tight fit is preferred. See Figure C.
15. If the drill bit is too loose or does not fit, adjust by bending the cable bracket as required.
16. Place plastic wedge on remote bracket as shown. Wedge must fit with at least a light press fit for retention. See Figure D.
17. After installation, Apply a dab of special Teflon grease, supplied with the service cable to cable housing openings at inside handle end. The grease should surround and contact the cable all the way around, to seal the opening between the cable and the cable housing.
18. Check all latch functions to insure correct assembly of latch system. If the inside handle does not release properly, replace the inside handle remote release mechanism.
19. Reposition and install trim panel using new push pins if required.
Dec 07, 2010 | 1993 Ford F250
I have a 2006 Saturn Vue. The front passenger
there is a spring inside the door lock that makes it work this spring is most likely broken try spraying lubricant on the lock just in case its binding ,but it seems like you will have to replace the lock mechanism
Feb 07, 2010 | 2006 Saturn Vue
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Sharp R-308J microwave door will not latch
If you gently push up on the door latch head assembly (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
We have critical safety & disassembly info at our site, linked here.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
Jan 11, 2009 | Microwave Ovens
2001 Ford Explorer Sport
Common problem on 2001 Ford Explores. The reason why your door handle doesn't unlock the door(can't be unlocked by remote either)is due to a broken spring located on the backside of the door handel INSIDE the door. True that your one(or two) of your small exterior springs on your door handle are broken(will cause your handle to flap) but this IS NOT YOUR PROBLEM. The door locks will work if there is a bit of tension holding the handle bracket up. I know it's hard to explain without pics. but here's the ONLY WAY TO FIX THIS. It's not that hard.......... Remove the door panel, only a few screws and a few more holding trim around exit handle then, pull out "snap in" clips on bottom. With a flashlight you'll see back side of door handle. To get to that area you'll have to remove one bolt holding a window frame. Do that(with window in up position) then slide down rail, out of your way. Now, get back to handle. With your light aimed at the backside of handle left slowly the door handle as normal, and you'll realize(while looking at the mechanism) that tension(pulling down of bracket) needs to occur in order for locks(manual and remote)to work properly. Trust me.....you'll figure it out. Once you do, get a spring(pen spring, 30 cent hardware store spring, any small spring!) and hook one end to bracket and the other end to ANYTHING(OUT OF THE WAY) below the door handle thus, causing SLIGHT tension. Try your locks...THEY WILL WORK! YEAH! Replace that one window frame bolt(try your window...just the make sure), replace door panel and your done. TOTAL COST: 30 cents or FREE(if you have a small spring) Ford dealers will charge $150 to $285! Yikes!
Jan 08, 2009 | 2001 Ford Explorer
Frigidaire Dishwasher
yeppers..and get her another trampoline(have a 5 year old, meself.)
Jun 03, 2008 | Frigidaire FDB658RA Built-in Dishwasher
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
