Question about Garden
Hi i have a mountfield rv40.Not been used for a while.put fresch fuel in it, started it up fine but cut out after few secondsanyone help me?have checked fuel for tank to carbhave taken carb apart and cleaned by handseems to me there is not enough fuel getting to engine?help anyone?
    Sergeant:
  • 337 Answers
Tom Make sure that the gaskets on the carb are back good and tight. They may be worn due to taking it apart. The engine sucks the fuel through with the vac seal caused by the piston drawing. If the carb 'o'ring is not seated right it wont create a proper seal.
Posted on Jul 20, 2013
moretons
  • 155 Answers
SOURCE: 7.0 hp OHV Platinum Plus engine on a power washer
If you can get the carby bowl off the main jet is up the centre sounds like its blocked there should be a model type and code on the engine cowl or on the rocker cover you can look up an exploded view on a site called pats small engines
Posted on Jul 27, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
rycgl
  • 1545 Answers
SOURCE: AH520 Tecumseh engine will not start; no spark to
I would recommend a serious carburetor cleaning or even installing a new rebuild kit after the machine setting up for so long. The spark problem must be checked for either the (magneto to flywheel air gap) or the condition of the electrical points and condensor on it (if this older model has them)
Posted on Sep 20, 2010
hunter19_46m
  • 7482 Answers
SOURCE: After start up engine sputters and dies within 5
Hi global204...
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
NOTE: Before you disassemble the carburetor:
Make sure you mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you dissemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 27, 2011
juliefarley
  • 17 Answers
SOURCE: 1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Posted on Jul 18, 2011
Jul 17, 2011 | Garden
Hi, 1997 monte carlo that idles, but cuts out when put in gear, or at times while driving. 3.1 engine. 184,000 mi.
I don't have an answer for you, but I do have a similar or maybe even the same issue with mine. It usually starts up fine, and idles and runs fine when first started, however a few blocks or a few miles down the road it starts to cut out on me, sometimes dying completely... throwing it into neutral and pumping the gas usually will keep it running. This has gone on for a couple of months. When it does die, It normally will restart after sitting for a few minutes. Then a couple of weeks ago it died on me (normally this happens when slowing down and coming to a stop,) and would not restart even after a 1/2 hr, I had to have it towed. I periodically attempted to start it for over a week, it would turn over, but nothing more...then someone suggested that I disconnect the auto start box...It started right up. However, it still continues to cut out when slowing or stopping unless thrown into neutral and pumping the gas. It seems to run better on the open highway, than it does in town with all the slower speed and stop n go. I bought this car used about 6 mos. ago, and considering it's age and the 135K miles on it, I don't want to put any more money into it. I just read there is a recall on this vehicle for the fuel pump and additionally the fuel assembly, I'm not sure if this would be the answer to the whole problem or not.
Dec 30, 2010 | 1997 Chevrolet Monte Carlo
Running problems with Mountfield HP454 petrol lawnmower
First thing to check is the air filter. It may be plugged.
May 28, 2010 | Mtd 22" Yard Machine Push Mower
My Mountfield Petrol mower cuts out after 5 or ten seconds. The fuel tank is full
Remove fuel car and re-test. If no problem, the vent hole in the cap is blocked. Need more info about engine type to help further.
Mar 08, 2010 | Garden
Escort van 55 reg51 plate won't start.Few weeks
change engine on my 1.8d van after fitting the engine now the van wont crank over
Dec 29, 2009 | 2000 Ford Escort
Wont start and lost manual for a mtd yardmachine 8/26
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets...but most of the time you will need to rebuild the carburetor. If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank. When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Dec 24, 2009 | Mtd 22" White Outdoor Self Propelled High...
My engine wont restart when its warm
SOUND LIKE YOUR FUEL INJECTORS CLOGGED.FILL UP FUEL TANK.PUT A BOTTLE OF FUEL INJECTOR CLEANER IN FUEL TANK.DRIVE A FEW MILES SO THE CLEANER CAN FLUSH OUT DIRTY INJECTORS.THIS SHOULD HELP.IF PROBLEM STILL EXIST.HAVE IT SCANNED.
Sep 27, 2009 | 2005 Volkswagen Golf
Transmission? fuel pump?? please help
Hi mightmike,
Have you tried changing your fuel filter,if so and it didn't help much-there's two fuel pump on the '90 240.ones under the car just about under rear passenger seat drivers-side(it's the rounder of the 2 that's there & has wires to it).the second is in the fuel tank.
Also check your fuses there's a fuse for both pumps(read the cover for fuse box(by the hood release lever.)Hopefully that will help you fix the problem.How's your air filter?spark plugs etc.(good tune-up does wonders!!!)
peace be with you yankeecatter
Aug 06, 2008 | 1990 Volvo 240
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
