Question about Sony MEX-BT5700U
Tuner problem my radio tuner does not detect even frequencies. example 101.2, 101.4, 101.6
My Kenwood Radio (New) for my boat doesn't tune properly on FM. For example, it only tunes to 94,1 or 94,3 but not to 94,2 It is just ,1 digit off the frequency on most stations. Tried it on manua
Kenwood receivers are usually tuned for their intended destination country, hence the frequency "stepping" of the tuners may differ between countries.
Was this receiver originally intended for your country's frequency? If yes, then contact Kenwood customer service for further advice.
If not, contact your local Kenwood service agent and ask whether the frequency stepping can be reprogrammed.
Feb 20, 2013 | Kenwood Car Audio & Video
How do u turn up a galaxy dx55v.
Hi, my name is John. Welcome to FixYa. Take off the cover, with the circuit side down, take a plastic tuning tool, you can get one at your local electronics store. turn your channel select to midway of the band. make sure your modulation is turned off. Key your mic and tune VR13 to the Maximum on the watt meter. this is for the power. Next, locate VR14 turn the modulation up, and say ahhhhhhhhh, repeat if needed. Thanks for choosing FixYa....John
Dec 01, 2010 | Galaxy Radios DX-55V Base CB Radio
Got a new mp3 fm modulator, no frequency is detected
u should set the fm frequency on your modulator as same as ur car radio. example, if ur radio states 100.00, set ur modulator 100.00 also.
Oct 10, 2009 | Virtual Reality Sound Labs VRFM7 MP3 FM...
Radio in my ford fiesta Reg 51, 2001 has stopped working.
it seem like a problem with the internal tuner. Somehow it detects diffrent frequency now, i am not familiar with frequency used in aircrafts, but I would gues they use higher frequency that FM bandwith. Capacitor lessen in value when they fail, so that would cause the local oscillator in your radio to detect higher frequency. As far as fixing them you would have to be an expert in radio comunication electronics. I for one a novice when it comes to how demodulation processes work and all that. Best solution is to put another radio, or you can take it to a CB shop. They maybe able to fix that. CB shops are usually around truck stops, because they service the CB radios that truckers use.
Jun 30, 2009 | Car Audio & Video
AM radio tuner set as MW tuner. How to switch to U.S.A. AM mode?
AM is just another name for MW. The Radio should tune to a strong signal regardless of the frequency the radio is set to. It should also sweep the entire frequency looking for stations. I'm assuming it has a channel scan setting, plus options to set a number for the station. AM/MW are very much dependent on the position of the either internal or external Ariel. If you have the radio in the wrong position or you have some electrical equipment nearby it could block the signal for the station you want, but not affect the others. Which might explain why it can't find the station you want.
May 05, 2017 | Philips DCM230/37 iPod Docking Executive...
Denon AVR 1909 - tuner audio intermittent - off and on repeatedly
Make sure you have an anteena connected and adjusted
Jan 29, 2009 | Denon AVR-1802 Receiver
Change Radio Frequency
Most radios made in American have fixed tuners and do not have a way to change frequency of the radio. If they use the same FM frequencies (88.1-108.0) then all you have to do is do a scan or seek of what is available when you get there or a new radio will be needed. There may be a way to add a EU tuner and have the original radio receive the output of it through a channel in the radio. It's the cheapest way to not have to buy a new NAV/RADIO device. It would work kind of like the hands free devices that are not hardwired do here.
Oct 18, 2008 | 2008 Subaru B9 Tribeca
Set frequancy
Mount your Roady 2 in your Truck .Make sure the power is on & the antenna is connected. The middle connection should be open. Push the menu button, you should see FM Frequency at the top.Push the scroll button(Top Right) and you should see FM station numbers. Scroll though the stations and pick a frequency that isnt being used in your area. Push the scroll button in to set the station. The display will show that number set 88.3 set for example. Set the FM Tuner in your truck to the same station. You should be go to go. Good Luck
Dec 18, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Sony MEX-BT5700U Logo
18 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
