Question about Troy Bilt 175HP Manual 42" Riding Mower
Riding down hill the mower jumped out of gear
Trans slips out of gear going down hill
Mower wont cut going up hill
there should be two drive belts. they should be replaced both at the same time. if one is wore so is the other one. use the correct belt, from a lawn mower parts store.
Aug 26, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
Hydrostatic trans getting weak going forward. Won't lug engine and have to go to low gear to pull hills it used to pull in B. Reverse is still strong. 380 hours, have change filter, oil looks good
The big pulley on top of the hydro axle is driven by a rubber belt.
V Drive belts pull from the two sides of the belt, as they wear down the bottom of the belt gets lower in the pulley making it loose and narrower then original. There is a idler pulley mounted on a arm with a big spring that pulls it tight to make belt not slip
Mar 14, 2016 | Garden
Husqvarna mower losing power
i will try to help... is it a hydro or geared hydro has a release on the back of the rider if the fluid is low then this can slip kick and make it seem like the trans axle is going out if its geared then they could be rounded off and causing you to stop slowly and not pull a hill
Oct 02, 2012 | Husqvarna Garden
Husqvarna 2754 ride on mower , the transmission seems to be weak it cannot go up hills it could before . How do i fix this?
most likely the trans drive belt has worn down and is now slipping,maybe tighten or replace.
Dec 24, 2010 | Husqvarna Garden
My craftsman lawn mower acts like its slipping going up small hills
check ur drive belt [ runs from the engine upper pulley under frame to the rear trans axle thru a series of pulleys and spring loaded adjusters] the belt has probably worn down or has streched to where it slips under a medium load
Mar 13, 2010 | Craftsman Garden
Ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Nov 09, 2009 | Mtd Gold 42" Zero-Turn Mower -
I have a 2005 husqvarna lawn tractor. 24 hp, 48 in deck, the transmission runs fine on level ground but when i go to an incline the tranny slips and i hear a clunking sound, and if i travel farther up hill...
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
May 09, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Troy Bilt 175HP Manual 42" Riding Mower Logo
83 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
