Oil furnace My cover oil furnace is rusty
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Yep it is
Posted on Oct 20, 2013
Faw 55 no fan operation
All fan switches should read open line or "OL" when the furnace is cool, but if the motor seems stiff see if it is oilable. It may have small holes covered by yellow or black plastic plugs covering the holes. If it does and you have not oiled it, go to the hardware store and ask for a motor oiler such as a Zoom spout. Place 3-5 drops of oil in each hole then spin the motor by hand, it may loosen up. The limit side of the fan/limit switch has no impact on the fan motor.
Feb 01, 2015 | Empire Comfort Systems EMP FAW-55-SPP-1N -...
I have an old popcorn maker. The kettle is very rusty. I'm using a carbon cleaner for all of the thick build up of oil, but how do I remove the rust?
Older Kettles that are rusty, will always be rusty. Use the carbon cleaner, and steel wool to remove the rust. But you must season the steel immediately after to stop new rust from forming.
To season the kettle, heat it up to operating temp, with a light coating of oil on it. You want to burn the oil, (creating Carbon) to stop new rust from happening. That is the only way to avoid new rust.
May 07, 2014 | Kitchen Appliances - Others
Gpg13300701
pull or disassemble that inducer clean out rusty, lubricate it with oil. Put it back it should work or you can replace it with new one
Feb 10, 2014 | Heating & Cooling
Furance will no come on
Have you tried pressing the reset button(s). Usually there is one on the blower motor and one on the stack where the exhaust gasses exit (old models), or near the oil pump, probably inside the big cover on the front of the furnace.
You didn't say if it is a gas fired or oil fired furnace. They can all be repaired if you have the tools and are handy, but usually repairs are best left to the pros. Youtube has some excellent videos posted by pros.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Jan 09, 2014 | Heating & Cooling
Old rusty tools
Hydrochloric acid, known as muriatic acid. The 20% concentrate is available in nearly any hardware store. You can leave your tools in it until the rust is broken down and dissolves.Use this in a well ventilated area as the stench can be quite bad. Also use rubber gloves and wash hands thoroughly afterwards.Wear eye protection too in case of splashes.
Once the tools are done soaking, remove and dry them, then lightly cover them in an oil or WD-40. Any moving tools such as ratchets may have to be stripped and cleaned before lubrication with grease.
Nov 04, 2012 | Cars & Trucks
I have a Onan 7.5 from 1998. only 80 hours on it. Would turn over very slow and would not start. Will not turn at all now. Fuel pump and celinoid kick in. Took out starter had it tested and it was ok. What...
If you have it for 12 years, it ran only 80 hours, it may have got rusty.
If you can open generator back cover, try to see the condition of generator iron (stator and rotor).Check the bearings.
Check the oil (level and condition, it may have water or gas in it).
Take out the spark plug and without fuel try to turn the motor manually.
If you can turn it, try to clean if any rusty parts, drain the oil, clean the crankcase with cleaning oil (make a few turns)and fill it with good new oil.
Try to spray some WD 40 or some rust remover spray where you may have rust: the generator interspace, bearing legs, through the spark plug hole etc.
Thats all I can advice now. If no result try another quiary.
Jul 13, 2010 | Watts Onan Portable Generator - 4000 ,...
Seat adjustment - rusty chain
To raise and lower your seat you need a spanner or a small shifter to loosen the nut that holds it. Or it may have an adjustment tightening and loosening lever under the seat on theframe of the bike. Depending on how rusty the chain is, I would firstly spray it with WD40 to free it up. I would then clean it off with some rags and heavily soak it with a good machine oil. EG: sewing machine oil is great.
Oct 30, 2009 | Cycling
I have a EVCON furnace DGAT070BDC. I replace the igniter control, the gas valve and the thermostat. Same problem continues: glow stick works, then the pilot lights works.The igniter control clicks...
You may have a dirty/rusty burner that is clogged or your gas valve
manifold pressure setting may be too low. Normal manifold pressure
is 3.5 inches water column on natural gas furnaces. ( 1 psig is equivalent to 28 inches water column). Pull and clean burner. Also
check and clean pilot assy. including flame sensor (if present).
Please let me know.
Oct 24, 2009 | Coleman Heating & Cooling
2002 daewoo lanos oil leak coming from out of timing cover
either the bolts need tightening or the ghasket is broken through or a rusty timing cover has rusted through causubg a leak ...clean the cover off with a degreaser and wash off and clean it allow to dry then with engine runnibg visually inspect without getting hands or clothing caught in fan or other moving parts and look to see exactly where it is beginning from ....if it is a rusty leak some materials will help cease the leak as well as a ghasket maker sealant may be used as well to stop the leak ..let me know from where it is and what form of /type leak it is merely the bolts may be just loose !
Sep 24, 2009 | 2000 Daewoo Lanos
Old oil furnace won't start
You have a flame rectifier that has to sense the flame. Try cleaning it just looks like a small round device off to the side. They get covered with soot and can't prove the flame is on. Let me know how it goes. ken
Jan 11, 2009 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
