Question about Welch Allyn Sure Temp Plus 692 Thermometer
E5.0 error sure temp - Welch Allyn Sure Temp Plus 692 Thermometer
When turning on power display reads 128 then error code r 13, after this it say's spa on but the temp reads 126 and the water temp is only about 68 so the heater never comes on.
This is not an error code. 128 r13 is the normal programming or software version for your model. you need to press the spa on button again, make sure the temp set point is higher then the actual water temperature
Mar 07, 2016 | Pentair Master Temp 400K BTU Natural Gas...
98 Buick Century. Temp gusher pegged when cold,odometer reads error, gear selector says 2,& oil light comes on when cold.
I agree , if it were only one area of error I would first and foremost say verify your temp with a point and shoot temp gun , but it sounds like you need new cluster , I'm sure the other Answer is also correct to re solder the components , but most just want it fixed quickly . I would also remove battery so when re installed your cpu re sets
Mar 22, 2015 | 1998 Buick Century
Error code tankless gas
E2 is a cold water inlet temp sensor. Has your unit experienced any freezing conditions? If it senses below 36 degrees or above 90 degrees it will show this error.
If its normal temp, and you still get this error...check your sensor. Its an 8(kohm) sensor. Make sure its not open. If it reads ok and your temp is not an issue, then you probably have a bad control board
Dec 15, 2013 | Bosch AquaStar 2400ES-NG
Error code e2
Dec 15, 2013 | Bosch Water Heaters
Bosch GWH2400 ENG has an E2 message
Whirlpool oven code E2F3, and oven never gets up to the correct temp.
The thermostat in the oven itself needs replacing. Unfortunately, you'll probably need to get a professional in to do this job.
Oct 21, 2012 | Whirlpool Stove / Oven / Range Cooktop -...
F-2 error on digital screen, mAYTAG GAS OVEN, SELF CLEANING not sure model #.
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 31, 2011 | Maytag CWG3100AAE Gas Oven
Printer error fuser temp
You will have to replace the fuser. Call 1-800-835-6100 and follow the prompts to purchase parts. It isnt real expensive. Just make sure you still don't have some warranty left on the parts.
Mar 09, 2010 | Xerox Phaser 3100MFP/S Laser Printer
The printer display says "Open Heat Error". What is this and what causes it?
I'm not real sure but I do know the the fuser area contains heat sensors. If the fuser temp is higher than it should be, you will get over-temp errors.
Get the printer serviced. It very well could be a motherboard failure or a fuser control card.
Don
Feb 18, 2010 | Dell 1600n All-In-One Laser Printer
When I try and print from Explorer I get the following Error ''cannot find file :///Users/User/AppData/Local/Temp/Low/W6C9HM4Q.HTM
Make sure your logging on as an administrator. if you are and the error persists try and see if you can find the temp file, if it exsists clear your temp folder in your internet explorer setting.
Hope it helps
Oct 12, 2009 | Computers & Internet
Welch Allyn Sure Temp Plus 692 Thermometer Logo
265 people viewed this question
Top Welch Allyn Home Experts
Donni Steen
Tom Chichester
Are you a Welch Allyn Home Expert? Answer questions, earn points and help others
