Question about Philips 47PFL7422D/37 Television
Won't power on
Plug it in...the blue light comes on for a few seconds, then the red light comes on and repeats the following sequence:blinks 6 times pause blinks 3 times fast I replaced the power supply board and now the TV does nothing...no lights no sounds...nothing
    Top Expert:
  • Philips Master
  • 34,170 Answers
You still have power supply trouble, even after replacement of the board. Recheck the replacement work; could be something wrong there
Posted on Jul 19, 2013
Testimonial: "Well, the board was used, so I'm wondering if the board is any good. Don't think it's the replacement work because I put the old board back on and does the blinking..."
  • 138 Answers
SOURCE: Philips 37PF7320A/37 Doent stay powered on...red lite blinks three times, pauses, then repeats itself
contact www.wehavepart.com 1-800-575-9833 for the part and see how much it cost. Or www.advancebaldwin.com or www.andrewselectronics.com./
Posted on Aug 20, 2008
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
dsacco86
  • 1077 Answers
SOURCE: Set will not power on.. Blinks red LED 8 times
It's a power supply related problem.
The flashing 8 times is a trouble code. A Service Manual for your TV model will have the info on the codes. It could be a bad capacitor or a transformer on the power supply board.If you have some electronic experience, you can find a Service Manual for your TV over the internet. Cost about under $20.
Posted on Jul 31, 2009
SOURCE: Cannot get set (picture or sound) to come on.
cant find signal with or without cable box
Posted on Oct 05, 2009
  • 5102 Answers
SOURCE: What does the 6 slow blinking red lights followed
Try unplugging the TV and then plugging it back in after a bit (at least 10 seconds). In several cases, the TV will start to work for a while.
However, the blinking indicates a part or parts that are getting close to failure. Most often this is 2-4 capacitors on the main board. These can be replaced (either by yourself or by a technician if the TV is under an extended warranty). Radio Shack will have the parts; a site called tvrepairkits.com has many prepackaged sets - check for your model.
I hope this helps.
Posted on Apr 24, 2010
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Error code 13 on mitsubishi wd52628
wait for the light to go out then press power. Then if it doesnt power up hold the menu and the Device/input buttons on the set both in together for 5 seconds the light will blink a series of blinks pause briefly then blink another number of blinks then pause then it will repeat the same two digit blink sequence a few times . Let me know the two digit blink sequence.
Aug 29, 2012 | Mitsubishi WD-52628 52" Projection HDTV
I have a sony 65 in. sxrd projection tv that has the red power light blinking and the tv won't come on?
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 16, 2011 | Sony Televison & Video
Red standby button comes on after power comes on. It blinks 13 times, pauses few seconds, then 13 more blinks
May 25, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Have a ws 73-711 that does not turn on. If you unplug it then plug it back in you get a rapped green flashing light for a few seconds then nothing. any help would be great
Have you tried accessing the led self diagnosis by pressing the menu button and Input button both in together and hold for 6 seconds on the front panel of the set. It should then blink a two digit blink sequence from the power indicator. which will repeat several times let me know the blink sequence and I will assist you.
Feb 18, 2011 | Mitsubishi WS-73711 73" Rear Projection...
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Jul 30, 2009 | Philips 32PFL5322D Television
Kdf55wf655 55 inch sony wega 6 blinking lred lights
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
May 30, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Philips 47PFL7422D/37 Television Logo
152 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
