Lg tv cf20s12e
My LG TV screen doesn't display the icons we select via remote such as volume, channel no,menu option etc..
    Champion:
  • 247 Answers
CHECK TV OSD(ON SCREEN DISPLAY ) SETTING
Posted on Jul 19, 2013
SOURCE: LG 37LC7D remote doesn't work
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Posted on Oct 31, 2007
  • 362 Answers
SOURCE: remot not working for Sens TV/DVD 19''
Hi sifrid,
Program the RCA remote with the instructions below, this will tell us if the problem is with the remote or the tv.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Posted on Jan 27, 2009
jerryg50
  • 1667 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
  • 136 Answers
SOURCE: lg lcd tv keeps changing chanels
Come on, lets try to solve this. Take the batteries out of the remote so it can't interfere and try changing the channels and volume with the buttons on the tv. If this works then someone has spillled something onto the remote and gummed it all out. You simply need to take the remote apart and clean it out. If the buttons on the tv do th same as the remote did then yes, take it back.
Posted on Aug 08, 2009
SOURCE: Closed Captioning on LG 50 DM
i have the same problem with the closed captions... i believe to turn off the captions you have to use the remote. press the CC button repeatedly until closed captioning turns off. in my case i lost my remote so i am unable to use the method to solve the issue. Can someone please confirm that this works. so i can buy a replacement remote. Thx
Posted on Jan 13, 2011
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
How can I connect my TV to a Dell laptop via HDMI?
if oyur LG tv has multiple HDMI ports, then you might need to choose the correct HDMI port from the 'INPUT' menu. Does the HDMI port on TV (sidepanel / back) has a sticker which denotes the number? if yes, then on tv remote, choose INPUT /SOURCE menu, it will show TV, Component, RGB, HDMI1 , HDMI2, HDM3, etc (depending your tv model, these options might vary) and choose the port number which you plugged the HDMI into. if you do not have a number on the port, then you might need to select each HDMI from "INPUT' menu and wait for a couple of seconds.
Sep 01, 2015 | LG Televison & Video
What is the code for LG 47la860w to work with my Sky + hd remote Control
0392,0390. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Jan 25, 2014 | LG Televison & Video
Pc reads tv through hdmi but tv says no signal still what do i need to do?
The TV reads the PC via the HDMI out from the computer. You must make a direct connection from the PC to the HDMI input on the TV with a proper HDMI cable. Once that is established, you need to be certain what HDMI Channel is represented on the TV, HDMI #1, 2 or 3? Etc. Best you turn on the PC AFTER all connections are made and the TV is in full operation and the channel HDMI 1,2,or 3 etc. are on. Now turn on the PC and see if you get a connection. You may have a picture if you are streaming a video, and NO sound. If so, reset the Audio by clicking on the speaker icon at the lower right of your computer screen, and in the Volume Control Options select the output you wish to use.
Jan 05, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
Hi, I have an LG RZ-20A70 TV and when i watch TV or play xbox the side are cut off the screen. (think its the picture ratio) any idea how to change this? as i have tried everything!
yes it is a picture ratio issue .
You need to look for the main menu tv setup button, its green on my lg remote .
Once you select this you should have an option to change screen ratio to 16.2 or wide screen if your tv supports wide screen .
Look for a little tv icon on screen and select that ,this should get you to pic set .
Jun 16, 2011 | LG RZ-20LA70 20 in. LCD Television
I dont have the remote for my lg tv. I have just got sky but the picture is wider than the tv screen now. It also gets taller than the screen. Is there any way to cure this?
u should have options under your tv menu to cure this there shld be a menu button on your tv beside the channel or volume buttons
Feb 16, 2011 | LG Televison & Video
Tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Dec 29, 2008 | Vizio L32 32 in. LCD HDTV
LG HD Digital Video Recorder LST 5402P has stopped displaying menu onscreen
first i assume you are trying to watch the unit through AV. If this is the case, turn on unit, press "Display Format" on the front of the unit, keep press it till you have "YPBPR" displaying, press select on front panel, next press "Display Format" again till you come to 576i, press select. Now press menu and it should display. If this problem occurs with HDMI, simply change the display settings to HDMI, and 1080i. Hope it helps, Murder-face.
Jan 13, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
