Question about Haier HBF05EBSS Commercial Beverage Dispenser
Defrost ice is forming inside my kegerator. Is there an auto defrost function?
Large Ice Build up on top inside back of fridge unit.
Could be the auto-defrost has stopped working. Most modern frost-free fridges have a heating element behind the liner where the cooling element is and the ice forms. Between the thermostat controlled periods of cooling the heating element should switch on for a short time to melt any ice that has formed and the resulting water forms into droplets that roll down the fridge liner until it is channelled into a drain leading to a tray mounted on the electric motor. The warmth from the motor evaporates the water and completes the maintenance-free frost-free system.
Possibilities are faulty wiring/connections, defrost timer, defrost element.
The defrost timer could be integral with the thermostat.
Some older fridges had a manual switch to start the defrost process.
Jun 30, 2016 | Refrigerators
2000 honda accord heater mode ? auto mode works, defrost mode does not
Is the a/c compressor turning on? When you turn the defroster on, the a/c compressor turns on to help remove moisture from the interior of the vehicle which in turns clears the fogging from the windows. If the a/c doesn't work, the defroster won't either.
Jan 14, 2015 | 2000 Honda Accord
I have a sheet of ice inside my bottom freezer below the food drawers. How can I get rid of this and prevent it from forming?
Reduce the cooling control. Defrost it regularly. If it is no frost refrigerator then your automatic defrosting is not functioning. Check the heater & timer functioning. The schematic diagram is normally pasted on the back of every refrigerator.
sonsunny
Jun 19, 2011 | Refrigerators
Our Refigerator is forming ice in the freezer. It
Probably has lost the defrost function and excess ice has formed clogging air flow and shutting down ice production. Remove the access panel and inspect the evaporaton department for signs of failed defrosting.
Apr 22, 2010 | Refrigerators
LARGE AMOUNTS OF ICE FORMED IN THE MAIN COMPARTMENT
Well, short term, you'll have to unoad it and defrost manually.
Sounds like the auto-defrosting system has a problem. A likely cause is the defrost timer.
May 04, 2009 | Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Mar 17, 2009 | GE GSL22JFPBS Side by Side Refrigerator
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Haier HBF05EBSS Commercial Beverage Dispenser Logo
23 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
