Question about Garden
42 IN 21HP BRIGGS &STRATTON
WHY IS THERE A LOT OF SMOKE COMING SOMETIMES FROM FRONT OF MOWER IS NEW USED 3 TIMES
    Problem Solver:
  • 17 Answers
Deck belt is slipping. Are you cutting too low? May need a belt replacement?
Posted on Jul 20, 2013
4 Suggested Answers
  • 246 Answers
SOURCE: coils keep burning out on 12.5 hp briggs &
Hello:
>>Have you Replaced the Coil with a New One?
>>If No, then Replace the COil and your Problem will be Corrected. The Ign Mosule inside the Coil is Heating Up and Shorting Out. This Causes the No Fire when Hot Problem.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 2239 Answers
SOURCE: Briggs & Stratton R mower/14.5 hp. Starter engages. Engine stops on compression. Has new starter & battery. Cabels are good. Sometimes it will start & run.
Incorrect valve tappet clearances, this will stop the auto deco valve in the engine working.
Posted on Apr 14, 2012
  • 6468 Answers
SOURCE: Ariens 1640 Zoom Riding Mower with Briggs & Stratton engine smoking
check to see if the oil smells like gas the needle valves go bad in the carb and gas over flows into the crank case also the head gaskets go bad and **** the oil from the crank case
Posted on May 10, 2012
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
42 IN 21HP BRIGGS this has only been used 3 time lot of smoke coming from mower sometimes ground is wet in parts was hard to restart
If this is new I would take it back, having said that, check all fluids and make sure you have fresh gas. Make sure oil level isn't overfull.
Jul 19, 2013 | Garden
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
Starts then stops
a plugged jet inside the carb
Aug 27, 2012 | Briggs & Stratton Briggs Stratton...
Model:31P977 Type: 0635-E1 Code:070510ZD Just bought this used. When they showed it to me it did not smoke. I started it up in the yard and after a few minutes...blue smoke started coming out of the...
I would say that you have worn or cracked piston tings and perhaps in need of a new head gasket. After you have had it running for awhile and then shut it off for a short period and restart it does it smoke as much as it would after waiting for an hour?With any sort of luck maybe your engine has not seen much use and will straighten up.You might try some sea-foam in both the gas and crankcase to help clean up the engine.You can get this product at most auto parts store.I have been using it for thirty years in all my engines small and large and think it's an excellent product. Best of luck and thank you.
Aug 29, 2011 | Briggs & Stratton Briggs Stratton Intek V...
White smoke coming from front of mower. a lot of white smoke.
Your exhaust pipe actually exits from the front of your mower you most likely need an oil change. have them check your head seals as well.
Aug 04, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
14 HP vertical shaft sucks a lot of oil into engine at times
check for blockages from the head back down into the crank case also clean out the pcv valve and oil seperator if it has one
Apr 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
