Question about Coffee Makers & Espresso Machines
Instruction manual for Maxim Expres Model EX 102
Purchased a used Maxim Espresso/Cappuccino model ex 102. Instruction manual was missing. Where may I download/purchase an instruction manual?
  • Mike M
    Mike M Sep 16, 2016
    I can't find my manual (if it had one) either, nor the recipe book that came along with it. I did find some bare instructions on the side of the box, which I kept. Here are the directions: My comments are in parentheses.
    1. Pour in water. (Take off the black cap at the top of machine and pour it in.) The large easy-t0-fill opening holds up to 4 demitasse cups.
    2. Insert coffee basket. Fill with your favorite espresso blend. Measuring scoop included. (Make sure you use espresso grind. I don't believe regular coffee works.)
    3. Turn on switch. The illuminated on-off switch starts the coffee brewing.
    4. Milk is steamed WHILE the coffee brews. A simple turn of the knob steams the milk quickly and easily. The frothy milk then tops off your espresso for a delicious cappuccino. Add cinnamon or nutmeg for a delightful finishing touch.
    Hope this helps.
Salton EX 20 manual
Hello:
I had the same problem, I needed the instruction manual for Salton EX-20 Three for All. Searching the net I found the following answers:
Sep 05, 2010 | Vacuums
I need an instuction booklet for my salton model ex 96 esspresso machine
Go to:
http://www.coffeecrew.com/learning/185-the-salton-maxim-ex96-manual-for-everyone
Jun 04, 2009 | Coffee Makers & Espresso Machines
INSTRUCTION BOOKLET
Click Casio Support to download instruction manual of EX-S10
Feb 27, 2009 | Casio Exilim Card EX-S100 Digital Camera
Where to fine a owners manual
I own a Maxim Expres machine. I no longer use it nor have the manual, but the following are my recollections.
I have the version with an on/off switch on the front and a separate knob to control the steam nozzle.
- Use the carafe to measure the water, then pour into the tank and replace the screw-on lid.
- Measure coffee into the metal basket (don't remember the proportions of coffee to water - you
have to experiment.)
- I tamped the coffee lightly - not as much pressure as you use with a pump-driven machine.
- Put the basket into the handle, line up the slots and twist the handle to the side to secure (I'm
sure the models vary in this regard). Place the carafe under the drip hole.
- Push the button to "on". For espresso, just wait until it stops dripping. This is a steam-driven
machine - don't expect much or any crema.
- Frothing: If you are going to froth milk, you need to do it WHILE THE COFFEE IS DRIPPING.
-Wait until coffee starts dripping into the carafe (otherwise there is not enough steam pressure)
-Submerge the nozzle tip under the surface of the milk and turn the knob on the steam nozzle.
-After frothing, turn the nozzle to closed and wait for coffee to finish.
-If you wait too long to start frothing, the coffee will finish and you will lose steam pressure.
That's what I remember, hope it helps.
May 25, 2008 | Coffee Makers & Espresso Machines
Salton "three for all plus" coffee espresso maker instructions
the following site will take you directly to the salton info file. site says if you email them they will get you an instruction file. http://www.singleservecoffee.com/archives/000517.php
Sep 21, 2007 | Salton EX20 Coffee Maker, Espresso Machine
Instructions
Hello:
Enjoy,
JC Contin
May 27, 2007 | Salton EX20 Coffee Maker, Espresso Machine
Coffee Makers & Espresso Machines Logo
812 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
