Tengo la red inalambrica deshabilitadad y no encuentro el drivers teengo windows7 es una acer aspire 4520
Google translated
engo deshabilitadad wireless network and can not find the drivers windows7 teengo is a acer aspire 4520
Your Acer computer has a networking card installed so that
it can connect to a wireless local area network (LAN) to share files or surf
the Web.
By using a wireless network, you can bypass the need to run
cables between different rooms in your office or home.
To set up a wireless LAN, you will need to change settings
in the computer's operating system and use the eNet Management software that
Acer provided.
Connect an Ethernet cable to the "Wide Area Network" port on the back
end of your wireless router.
Attach the other end of the cable to the Ethernet port on
the back end of your high-speed modem.
nsert the installation disc that came with the wireless router into your Acer
computer's disc drive.
Follow the on-screen installation instructions.
Access the Acer's Start menu and open the Control Panel.
Click "Network and Sharing Center," and then
choose the "Set up a new connection or network" link.
Choose "Set up a new network" and then "Next."
Enter a name for your local area network, such as
"Home" or "My Network," into the "Network Name"
text field.
Type a password for your network in the "Security
Key" text box and click "Next."
Click "Finish." Right-click the "Acer eNet
Management" icon in the Windows task bar.
Scroll to "Available WLANs" and then click the
name of the network that you chose earlier.
Type in the password you chose earlier and click
"OK" to connect your Acer to the Wireless LAN.
You only need to check
the BIOS if you cant install the driver
Make
sure you Ethernet/internet is enabled in bios restart your
computer during the boot up process you will see on your screen a certain key
to
press
to enter set up (BIOS) press and hold that key to enter bios using arrow keys
navigate to integrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press
enter make sure its
"Enabled"ima
SOURCE: problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
SOURCE: TENGO UNA ASPIRE 5710Z LE ACABAN DE PONER EL
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
abarasa67
SOURCE: TENGO UN PROBLEMA MI PORTATIL
check you have correct P.S.U. for your machine and it has correct polarity and is connected up correctly(look for small "arrow" on side of connector)if the P.S.U. is not original
