Question about Yard Machines Garden
Starter solenoid contacts
My mower will start is I hard Jump it, but it will not start off the battery, battery is charged and brandnew,
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,095 Answers
Are you getting Voltage from the switch to the solenoid?
Maybe a bad switch. these switches are very cheesy
Posted on Jul 21, 2013
  • 22 Answers
SOURCE: Must battery be at full 12v charge to start mower
lawnmower batterys usually dont last as long as one would like maybe you should buy a new battery.you might try jumping the mower with a car as long as the mowers battery is 12 volt
Posted on Apr 06, 2009
  • 59 Answers
SOURCE: mower won't start
sounds like the ground cable is bad
Posted on Jun 26, 2009
  • 2468 Answers
SOURCE: mower wont start
how old is the battery,unfortunately they do not last very long maybe 2 years average due to non-use,vibration,have it load tested and the charging circuit output tested for output when its running at a high idle speed
Posted on May 13, 2010
  • 640 Answers
SOURCE: john deere stx 38 with black deck, will not do
I see this problem not as an electrical but a seize problem. Since I can't be there to inspect I am relying on your discription of the problem. I would go first to the place of the problem. If this solenoid goes up to disengage and down to engage ,or the opposite, this is most likely your problem area. It may be seized in the disengaged position therefore not allowing the blades to get spinning. Disconnect the belt and try to turn unit by hand, if tight or completely stuck use penetrating oil on pulley shaft.If shaft loosens up and blades engage this was the problem. Is there a grease fitting anywhere in the area?I hope this at least gets you started in the right direction. GOOD LUCK.
Posted on Jun 17, 2011
aquaman987
  • 927 Answers
SOURCE: Have a Husqvarna riding mower
For a riding mower to start, all of the safety interlocks must be "made".
The brake may have to be set.
The transmission may have to be in neutral.
The blades must be disengaged.
The driver may have to be in the seat.
If one of the necessary interlocks is not "made", the mower will not start.
Gary
Posted on Jun 18, 2011
Starting procedure,service manual, wiring diagram
Please try to remove battery and take it to BATTERIES PLUS store so they can run a voltage test? This could be a great source of help. I believe the battery is dis-charging. Thank you. Please leave feedback
Jul 11, 2016 | Mtd Garden
Riding mower won't start & makes clicking sound when I turn key over
MAKE SURE BATTERY IS CHARGED IF IS THEN JUMP LAWN MOWER AT STARTER IF STARTS BAD BATTERY ARE STARTER RELAY COST 60.00 I STILL THINK YOUR BATTERY IS BAD OR DEAD NOT ENOUGH CHARGE IN IT
Sep 01, 2014 | Garden
My craftsman yt1000 23bhp, i have been jump leading my mower for around 6 months now, i started my mower last night no problem but got up this morning, turned the key and it just buzzed. so i origonally...
check the solenoid if you been jumping it off you could have burned it out and possibly the starter replace the solenoid first thats the cheap route and if that dosnt fix it check the starter if its buzzing or clicking its gone bad feel if it get hot if it does thats the bad sign to look for, replace solenoid, then starter thats my advise need more info messege me back for more, thanks, jamie
Dec 27, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
Have a Husky yth180 mower. Battery was going bad and wouldn't start so I jumped it to finish mowing. Replaced battery and still won't turnover. Jumped starter and does turnover. All switches...
hi there dolson894
here is web site for owners manual
http://lawnandgarden.manualsonline.com/manuals/mfg/husqvarna/yth180.html
download owners yth180 manual it has a wiring diagram in it - may help
sounds like a starter solenoid problem, check for good grounding of the negative bat cable and grounding of the solenoid to the frame , check for 12 volt at the solenoid tab ( not the heavy contacts)
this wire solenoid tab wire comes from the S marked terminal from the main switch and power from the battery is taken from the HOT post of the starter solenoid up to the B terminal of the main switch, from there when contact made between B + L + S @ SWITCH voltage sent to solenoid for start
basic connections for switch in start mode is B + L + S
run / light B + L and Makes A + Y
run B + L off G+ M +L
check seat switch and brake switch - bypass with jump wire if need
across white to wjite wires on brake switch
see what hapens , the try a jump wire across the seat switch wires green to green and retry
if stil no good - replace solenoid as you mentioned with a jump cable straight on start motor turns over good
check out website
cheers hope it helps pauly46
dont forget the thumbs rating
Jun 07, 2011 | Husqvarna Garden
I have a riding mower that will not turn over. I used jumper cabels attached to my car, stupid I've been told. I have done this before and the mower will start. When attached the mower engine will...
it is hard to say exactly what the problem is, but it sounds like the starter, starter solenoid, and or a charging problem. 1. last year I am assuming that the battery was low on charge and once you jumped it, it would start with the key for the rest of the season? if yes your battery should be OK just make sure at the end of the season you disconnect it and store it some where cool but not freezing. if you had to jump it all the time the battery and charging system has problems,(cables)(?). 2. if you have to use the car to jump the mower make sure the mower and car are both 12 volt systems, and the car should not be running. 3. make sure the battery is fully charged and there is no corrosion between the cables and connections. 4. once you do the above you can jump the solenoid to see if the starter is bad, if it moves it should be good, if you have to jump the solenoid make sure the mower is in neutral and the wheels are locked so it cant jump forward. also make sure all your safety switches are engaged, most mowers have switches on the seat, the blade engageing handle, and breaks.
The lights might have a bad connection at the battery, follow the wires from the lights for fuses and check them, some models have to be started before you can turn the switch back to turn the lights on.
May 13, 2011 | Garden
Mower will run if jump started and continue to run but when turned off and back on will not start until jumped again.Meter does not show mower is charging
The battery needs to be checked.If its running with jump start this indicates that mower is fine but the battery is not supporting it for normal start.In some cases the battery has low charge so getting the battery charged helps.In some cases the battery is dead so battery needs to be replaced.And in some cases the battery is new ,its charged but actually the terminals from the battery gets rusted and do not get connected so this leads the problem.So check the battery,if its low on charge get it charged,if its not getting charged then replace the battery ,if its charged and new then clean its terminals and reconnect and check. But if battery is properly charged and connected properly ,then also you see the same problem then its fault in the starter and starter solenoid.It needs to be checked and replaced.
Thanks. Keep updated for any more query.you can rate this solution and show your appreciation.
Jun 26, 2010 | Garden
Jump solenoid with screwdriver
Turn key to run. Put screw driver to battery cable side while holding the plastic end of screw driver touch other end of screw driver to cable that goes to starter on solenoid and wjth full charge of battery you should have starter turning.
Mar 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Clicking noise when car starts
The clicking noise is from the solenoid. If the battery is weak, then there is not enough current to make the starter turn. Therefore it is not necessary the starter is a problem. One of my experience is that the contact inside the solenoid can be rusty, corroded so there is not enough current flowing to the starter to make it work. The easy way to find out is to charge up the battery, or to have a jump start to see if the starter turns. If it turns then the problem with the battery. If with a new battery and still needing a jump start then the problem is the solenoid contacts, hence the solenoid needs to be replaced.
Dec 01, 2009 | 1999 Plymouth Voyager
2140 cub wont turn over when trying to start
Change the solenoid, if you can jump the posts on the solenoid and the engine turns over...the solenoid is bad
Apr 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
37 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
