Question about Pioneer AVIC-N1 In-Dash DVD Multimedia AV Navigation Receiver Car Video Player
Directions are off and the alert comes too late
When I enter an address or choose one from address book or a POI, it gives the direction alerts late or not at all. Even POI that I have saved, it does not map directions to that area well and the same problems listed above occur. How can I re-calibrate or reset the system.
  • 4 Answers
This is the total reset process step by step i found it on
www.avicx1forums.com and it worked fine.
REMOVE DISK
HOLD RESET AND EJECT
RELEASE RESET BUT HOLD EJECT
SCREEN WILL GO BACK IN AND OUT-THEN SAYS PLEASE PRESS THE RESET BUTTON…DON’T
THEN WITH JOY PAD PRESS …
UP,RIGHT,UP,RIGHT,DOWN,RIGHT,DOWN,RIGHT…THEN OK (JOYPAD BUTTON INWARDS)
PASSWORD SCREEN WILL COME ON SCREEN BREIFLY
TEST MODE SCREEN APEARS-CLICK JOYSTICK TO RIGHT ONCE
SCROLL DOWN TO NUMBER 6-PROGRAM FORCED WRITE (OK)
FIND NUMBER 1 SYSTEM PROGRAM (INSERT DISK --CNDV 40/50/60?)
PRESS 1 SYSTEM PROGRAM (OK)
SELECT 2 DVD/CD ROM (OK)
SELECT LANGUAGE… (ENGLISH)
PRESS (VIEW –POS) BUTTON
SHOULD SEE SYSTEM PROGRAM GOING UP IN %
WHEN FINISHED PRESS (BACK)
FIND NUMBER 6 PROGRAM FORCED WRITE AGAIN (OK)
NUMBER 3 APPLICATION PROGRAM (OK)
SELECT 1 UK ENGLISH...THEN PRESS (VIEW – POS) BUTTON
SHOULD SEE SYSTEM GOING UP IN %
TEST MODE PAGE 1
SELECT 6 - CLEAR BACK UP MEMORY (OK)
SHOULD SAY FINISHED THEN ASKS FOR RESET BUTTON TO BE PRESSED
PRESS RESET ON FRONT OF UNIT
START SAT NAV AGAIN
ASKES FOR LANGUAGE PRESS NO (READ TEXT)
SYSTEM STARTS
BUTTONS
OK = JOYPAD INWARD
BACK = JOYPAD TO THE LEFT…NOTE THIS WILL BRING YOU BACK TO PREVIOUS PAGE
BACK = BAND BUTTON ….NOTE THIS WILL TAKE YOU BACK TO THE MAIN MENU
Posted on Sep 26, 2008
Custom poi doesn't have Go
connect your gps to computer and look at the files in the poi folder. they should be gpx files. When poi loader does its thing it converts the csv files to gpx maybe something didn't work the last time you loaded files.
Nov 14, 2017 | Garmin Nuvi 1450LMT
My midland noaa weather alert is stuck in the tone mode and will not go to voice
Good morning, afternoon, evening or night; whatever time of day you you are viewing this solution posting. Thank you for choosing FixYa to assist you with your problem. Your problem is that your weather radio's 'Alert Type' setting is set on Tone and will not change to Voice. To change your 'Alert Type' setting...
1. Press Menu.
2. Press the down arrow button until you see 'ALT TYPE' displayed on your screen.
3. Press Select.
4. Press the down arrow directional button. You should see 'VOICE' on your screen.
5. Repeat step #3.
6. Repeat step #1 to exit.
You should now be able to receive voice alerts on your radio.Thank you for choosing FixYa as your one-stop solution spot for problems, questions, concerns and requests. Visit our website again in the future, and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
May 28, 2011 | Midland WR-100 Weather/RDS Radio
I have a Midland WR-100. The stations don't work, it just rings. Can I fix this?
Good morning, afternoon, evening or night; whatever time you're reading this. Your complaint is that the stations on your radio do not work and it just rings for no apparent reason? The possible cause of this could be your alert setting. Your alert setting may be set on TONE. When this setting is activated, a ringing sound will be played on your radio for 5 minutes or until any button other than the Weather/Snooze button, on your radio is pressed. If this is the cause to your problem, you need to change your alert type setting. Here are the steps to doing this task...
  1. Press the MENU button.
  2. Use the directional up button until "ALT TYPE" is showing on your screen.
  3. Press SELECT
  4. Using the directional up or down buttons, choose DISPLAY or VOICE.
  5. When this is done, press SELECT.
  6. Press the directional up button until "ALT TEST" is shown on the screen.
  7. Test your alert type to find out if you'd prefer this setting.
  8. If this setting is preferred,press SELECT and MENU to exit. If you prefer to choose another setting, press MENU, then the directional down button until "ALT TYPE" is showing on your screen. Repeat steps 3 through 8.
I hope this solves your problem. Reply back if it doesn't. Thank you for choosing FixYa as your one-stop solution spot for your problem. Make sure to read our Tips & How-to page for this product. Have a good morning, afternoon, evening or night; whatever time you're reading this solution.
Apr 19, 2011 | Midland WR-100 Weather/RDS Radio
Why does my weather radio just beep, no voice, no lights? I have put in all codes for my county
Good morning, afternoon, evening or night; whatever time of day you are viewing this. You want to know why your weather radio just beeps and no voice or lights function properly. This has nothing to do with the codes you put in for your county. This has to do was the type of alert setting that is programmed into the radio. The alert setting that you have programmed into the radio is probably that TONE alert type. When this is selected, the alert will sound for 5 minutes or until any button is pressed except for the Weather/Snooze button. If you want your alert type settings changed, press MENU and use the up and down directional buttons until "ALT TYPE" is displayed on the screen. Use those same directional buttons to choose the alert type of your choice. If you choose DISPLAY, a text alert will scroll on your screen and no audio alert type will be sounded. If VOICE is selected, an alert will be sounded 8 seconds and you will hear the voice of the weather broadcaster for 5 minutes. These are the only other alert types you can choose other than TONE. Once you have chosen your alert type, press SELECT and and press MENU to exit. Remember that the NWS will only alert you if the storm meets their serve weather criteria (meaning the storm has to be able to cause a certain amount of damage or life threatening to "Wake someone up in the middle of the night"). With this radio functioning properly, it can really help you out in the long run by alerting you with the lastest information of what's going on in your area. Thank you for choosing FixYa as your one-stop solution spot for your problems and thank you for reading my solution.I hope this is the solution to your problem and it clears up any confusion you may have. Have a good morning, afternoon, evening or night; whatever time of day you're reading this.
Apr 04, 2011 | Midland Weather/Hazard Radio with SAME...
Hi I have Samsung B2100 mobile phone. When I receive a message, the sound is so loud. Can you please tell me how to control the volume.
menu/settings/phone profiles, select profile, then choose options at the low left corner of display. Here, you can adjust type of sounds you want and its loudness. Navigate to the right with your central button and here you are navigating downwards: 1. - message alert type chooser, 2. - message alert tone, 3. - message alert repetition, 4. - email alert type, 5. - email alert tone, email alert repetition, and finaly, 6. - alert tone volume. To enter into the submenu, first click direct the central button, and then choose the volume with left or right part of your central button. I am not a perfect english speaker, therefore I hope I was clear enough making this explanation.
Dec 15, 2010 | Samsung B2100 Cell Phone
I am unable to set up alarm on phone.
  • 1
    Activate your phone's main menu. An array of icons will appear on your screen, and you can use the directional arrows to navigate through the various applications and features of your phone.
  • 2
    Go to "Settings" and open this feature. Select "Tools" and scroll down to "Alarm Clock."
  • 3
    Select "New Alarm," which will open a new window on the screen.
  • 4
    Scroll through the "Name," "Time," "Alert" and "Volume" categories, filling in the necessary information for these categories. Give the alarm a name, and under "Time" use the directional arrows to enter the specific time you want to awaken. "Alert" and "Volume" will allow you to customize the alarm sound and how loud it will be.
  • 5
    Click "Change" or "Set Alarm" when you have finished, and the alarm will be saved and programmed to ring at the time specified.
  • Nov 08, 2010 | Motorola Cell Phones
    How do i put phone on silent
    User profiles
    This is used to set up the different ways of incoming call prompts in various situations. Use
    the up/down key to choose this option and click the left functional key to enter. There are
    many modes of setting available and the default setting is the general mode.
    To switch to a new user profile, use the direction key to select the target mode and click
    “OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
    “activated” prompt, indicating that the user profile is active. The “headset” mode does not
    require activation; your phone will automatically switch to the “headset” mode if a headset
    is connected to your phone, and back to the previous mode when unplugged.
    You can also customize each user profile setting for your preference, the following
    operations are available:
    (1) Ring tone settings:
    Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
    Power on: set up the music for power on.
    Power off: set up the music for power off.
    Message: set up the message ring tone when a new message arrives.
    You can also download ring tones online.
    (2) Volume
    This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
    available. Enter this function and use the up/down key for testing and adjusting.
    (3) Alert type
    This is used to set up the alert type for incoming calls. Please select the suitable alert
    types in different situations.
    Mar 25, 2010 | Cell Phones
    Does the c210 have safety camera alert
    If you can add custom POI then yes it should do check out pocketgpsworld they will be able to help you
    Dec 03, 2009 | Garmin 010-00358-00 GPS Receiver
    How do I input an address to get the directions
    Touch the MAIN MENU in the top let corner.
    Touch the ADDRESS option.
    Touch the CHOOSE option.
    Enter the name of a State or Province and touch DONE.
    Use the keyboard to enter a City or Zip. Once the unit has determined the city, it will prompt you to enter an address. The unit will sometimes provide a list with more than one address that closely resembles the one you entered.
    Scroll through the list of addresses provided by the unit and make your selection. When an address is selected, a dialog box will appear with three choices: Add to Addressbook, Find on Map and Go To.
    The ADD TO ADDRESS BOOK will add the address to your list of contacts in the Address Book.
    FIND ON MAP will show you that location on the map screen.
    GO TO will start navigating you to the location and begin giving turn by turn instructions.
    Jul 09, 2009 | Lowrance XOG GPS Receiver
    Pioneer AVIC-N1 In-Dash DVD Multimedia AV Navigation Receiver Car Video Player Logo
    177 people viewed this question
    Top Pioneer Car Audio & Video Experts
    Marvin
    Marvin
    xxxxxx xxx
    Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
