Question about Canon imageRUNNER C3200 Copier
HOW TO PRINT DOUBLESIDE - Canon imageRUNNER C3200 Copier
    Champion:
  • 241 Answers
There is finishre tab in printer properties there is option for 2 sided printing
Posted on Jul 23, 2013
Why does some txt print when using ctrl shift print to print a document or email and some lines do not print at all?
There are two way email e-print.
A> Open email and select print area and see preview, if preview ok then you given print. If not ok then go to printer setting option and set printer paper or text. Then see print preview if ok then given print.
B> Second option is copy email print job any doc file or then print select and command given. But print before also check it print preview.
If any issue create i share a print related problems link please visit and read it. I hope solved your issues.
Source..ePrint Job Did Not Print
Thanks,
HP Phone Number
Jun 23, 2014 | HP Officejet Pro 8600 e-All-in-One Printer
Instructions to fit fixing kit to a hul161i integral fridge door
Why not using doubleside type to put the magnet on , start atleast by turning of the unit for three days so everything can be made clean and dry
Feb 15, 2014 | 760Li Brief instructions f01, f02, f03....
I have a pixma mp630 and i want to print just one page from multiple page in a document how can i do it?
Move the cursor to the page you want to print. Then click File - Print then in Page range select Print Current page - then click OK to print.
May 04, 2011 | Office Equipment & Supplies
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Can you doubleside print on an HP 2600n? If so, how?
You can but it would have to a manual. Meaning you print out the document and load it into the manual feeder to print the other side.
Your installed driver should support duplex printing so once the document print on the one side the machine will prompt you to place the document in the manual feed tray.
Oct 21, 2010 | HP Color LaserJet 2600n Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Pls help in this VB code, Sato CX400 barcode printer
jst try this u create a label from label printing software using ato font then make a prn
then attach u r vb code in to prn it will work
rohitjain
prn example-------------
A
Z
A
CB+18
Z
A
CD250,3300
Z
A
AR
Z
A
A100950647
Z
A
%2h416v0072BG01031>H23456111
%2PSP02h573v0021L0101XS922
%2PSP02h618v0021L0101XS18K
%2PSP02h415v0089L0101XS17125
%2PSP02h416v0039L0101XSPO124
%2PSP02h416v0022L0101XS215gms
%2PSP02h618v0043L0101XSDR37/0.20
%2PSP02h618v0064L0101XSDR37/0.20
%2PSP02h618v0085L0101XSDT/B44/0.82
Z
vb code example------------------
Open "LPT1" For Output As 1
Do While rs.EOF = False
For I = 1 To Val(Text1.Text)
Print #1, "A"
Print #1, "*&"
Print #1, "Z"
Print #1, "A"
Print #1, "CB+18"
Print #1, "Z"
Print #1, "A"
Print #1, "CD250,3300"
Print #1, "Z"
Print #1, "A"
Print #1, "AR"
Print #1, "Z"
Print #1, "A"
Print #1, "A100950647"
Print #1, "Z"
Print #1, "A"
X = "%2h380v0065BG01031>H"
Y = rs.Fields(6).Value
X = X + Y
Print #1, X
Print #1, "%2PSP02h618v0085L0101XSKT"
Print #1, "%2PSP02h600v0085L0101XS", rs.Fields(1).Value
Print #1, "%2PSP02h618v0064L0101XSNetWt"
Print #1, "%2PSP02h600v0063L0101XS", rs.Fields(2).Value
Print #1, "%2PSP02h618v0043L0101XSDiaWt"
Print #1, "%2PSP02h600v0041L0101XS", rs.Fields(3).Value
Print #1, "%2PSP02h618v0021L0101XSColWt"
Print #1, "%2PSP02h602v0021L0101XS", IIf(IsNull(rs.Fields(4).Value), " ", rs.Fields(4).Value)
Print #1, "%2PSP02h430v0084L0101XS", rs.Fields(5).Value
Print #1, "%2PSP02h371v0028L0101XS$"
Print #1, "%2PSP02h405v0028L0101XS", rs.Fields(7).Value
Print #1, "&"
Print #1, "Z"
Print #1, " A"
Print #1, " #E5"
Print #1, " Z"
Print #1, " A"
Print #1, " CS2"
Print #1, " Z"
Print #1, "A"
Print #1, " 0000"
Print #1, "TEXT1.TEXT"
Print #1, "/"
Print #1, "Z"
Feb 04, 2009 | SATO CX400 Thermal Label Printer
HP PSC 1300 All in one Printer
  1. Turn on the HP PSC and lower the print-carriage access door.
    The print carriage will move into the access area. Figure 1: Opening the print-carriage access door
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot.
      NOTE: The black cartridge is on the right side of the print carriage.
    Figure 2: Removing the print cartridge
      NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab.
      CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles.
    Figure 3: Removing the plastic tape
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place.
      CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle.
    Figure 4: Inserting the print cartridge
  5. Close the print-carriage access door.
Using a photo print cartridgegtabtop.gif To use the photo print cartridge, remove the black print cartridge and insert the photo print cartridge in its place.
The photo print cartridge can be purchased separately and will optimize the quality of printed photos.
With the tri-color print cartridge and photo print cartridge installed, you have a six-ink system, which provides enhanced quality photos. For printing regular text documents, use the black print cartridge.
Use a print cartridge protector to keep either print cartridge secure when it is not being used. Figure 5: Storing the print cartridge
c00034854.jpg 1 - Inserting the print cartridge
2 - Removing the print cartridge
Aligning the print cartridgesgtabtop.gif After installing or replacing a print cartridge, the HP PSC will automatically print a cartridge alignment page.
  1. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  2. Press Scan .
    The HP PSC will align the print cartridges. During the alignment the button LED will blink until the alignment is complete.
Aug 04, 2008 | HP PSC 1350 All-In-One Thermal Printer
How do I change HP 5610 print cartridges.
gtabseps.gif Introduction Follow the instructions below to replace the print cartridges. This document applies to the following products:
  • 5605
  • 5608
  • 5610, 5610v, 5610xi
Replace the print cartridges Step one: Remove the print cartridges
  1. Make sure the HP All-in-One is on. Press the On button to turn on the HP All-in-One. The On button is lit when the HP All-in-One is on. Figure 1: Press the On button to turn the product on c00442142.gif 1 - On button CAUTION: If the HP All-in-One is off when you open the print-carriage access door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by pulling it forward. The print carriage moves to the far right side of the HP All-in-One. Figure 2: Open the access door c00442143.gif
  3. Wait until the print carriage is idle and silent, and then lightly press down on a print cartridge to release it. Figure 3: The print carriage c00316910.gif
    • If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If you are replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: The print cartridges in the proper position c00442144.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  4. Pull the print cartridge toward you out of its slot.
Jun 21, 2008 | Office Equipment & Supplies
Canon imageRUNNER C3200 Copier Logo
24 people viewed this question
old marine
old marine
