Question about Magic Chef 5 cu. ft. / 142 liter Chest Freezer CFC0535GRW
Red light is on all the time, wont stop running
    Top Expert:
  • Magic Chef Master
  • 44,073 Answers
Some freezers have a pilot light that is constantly on whenever power is being applied. If the compressor seem to run constantly, check for a bad lid seal. Also, the thermostat may at may be defective
Posted on Jul 19, 2013
Testimonial: "thanks tom chichester,lid seal looks good,it must be the thermostat."
Alarm light Westpoint Chest Freezer
is it getting cold inside .why would you want MAX temp tho turn to mid point as a startingplace
Nov 22, 2015 | Freezers
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
Jul 08, 2014 | Zanussi Freezers
What does the red warning light by the triangle mean on a blomberg
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
My freezer has a different code number;ZFT710FW.I put quite a lot of food into the freezer yesterday and the alarm now keeps sounding,I have put the temperature up but the red light is still flashing...
Under normal operating conditions, the internal temperature of the freezer will ensure the long-term conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once.
When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food.
Fast Freeze function
If more than 3-4 kg of food is to be frozen:
1. Press the Fast Freeze Switch for 2-3 seconds to activate the fast-freeze function 6-24 hours before placing the fresh food in the freezer, the Yellow Fast Freeze Indicator Light will illuminate. The compressor will now run continuously, to ensure that the fresh food is frozen as quickly as possible.
2. It is possible to deactivate the function at any time by pressing the Fast Freeze Switch for 2-3 seconds.
3. Place the foods in the freezing compartments (indicated with graphics).
4. Once the food is completely frozen (it may take up to 24 hours) you can manually switch off the fastfreeze function by pressing the Fast Freeze Switch for 2- 3 seconds and the Yellow Fast Freeze Indicator light will also go out.
5. Move frozen food from the freezing compartments into the other compartments (storing compartments) to make room for another freezing.
If the Fast Freeze Switch is accidentally left on, the fast-freeze function will be automatically switched off 48 hours later. The Yellow Fast Freeze Indicator light will also go out.
I believe that you all understand. If you intend to freeze larger amount of food then certainly a few hours before some shopping switch on the fast freeze function.
Dado
Apr 26, 2013 | Zanussi ZFT710W Freezer
Ridare freezer alarm goes off and it wont freeze ice c ream
Hello grega1959 - If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit. This can be done by either by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the freezer. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the temperature control, control board, or a wiring harness. If this is the case, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Apr 14, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Zanussi Freezer Model ZFT710FW. The alam and red light occasionally go off, although everthing appears OK. Temp OK, door seal looks good, etc. After some time the red light goes off of its own...
Dado
Apr 11, 2013 | Zanussi 2.83 cu. ft. / 80 liter Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
RED HIGH TEMPRETURE LIGHT IS ON.WHAT IS THE USUAL
if the temperature rises above 30 degrees then this is to let you know that there is a problem.
it could be one of these problems:
dirty condender
condenser fan not running (if available)
freezer fan stop working
compressor valves bad
lost of freon (under charge)
defrost heaters not working
bi-metal t'stat not working
timer bad
if you need more help let me know
Mar 27, 2010 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Magic Chef 5 cu. ft. / 142 liter Chest Freezer CFC0535GRW Logo
208 people viewed this question
Top Magic Chef Freezers Experts
Dan Webster
Dan Webster
Offbelay
Level 1 Expert
AJMAL KHAN
Are you a Magic Chef Freezer Expert? Answer questions, earn points and help others
