Lanier 7313 copier Manual
I have a Lanier 7313 copier that someone gave me. This is a very small office and it works great. BUT I need a manual. It's not working property and I can't even explain what the problem is without a manual.
  • 58 Answers
SOURCE: Lanier Copier User Manual
Go on line to Lanier.com, chose manuals. Then put your model in and that you want the users manual and down load it. Most of these kind of manuals are free to copy.
Posted on Oct 17, 2007
  • 53 Answers
SOURCE: Xerox WorkCentre XE88 copier
Black line usually caused by cleaning blade failure or drum damage
If the fault only occurs when using document feeder and not off the glass, clean the scanner glass (the narrow strip at the side of main glass if fitted)
Drum /cleaning blades are usually contained in the "throw-away" cartridge It would be nice if you could find someone with same machine you could try a swap to prove it
Posted on Nov 16, 2007
jaylex
  • 417 Answers
SOURCE: LANIER COPIER 7313
I guess by your fault description that there is a blank gap before the printing starts? The only way to cure this problem is to replace the registration clutch as it is turning on too late and not releasing the paper quick enough. Also check that the paper tray dial is displaying the correct paper size and position.
Thanks Jason
Posted on Aug 17, 2008
  • 143 Answers
SOURCE: I have a Lanier 7313 Copier which doesn't copy
This machine goes through developer pretty quickly. Sounds to me like it needs new developer and possibly a drum (and drum blade).
Posted on Aug 24, 2009
cartridgecon
SOURCE: How do I reolace the toner in a lanier 7313
It was very easy. I just had not seen the machine when I posted the question. Thanks
Posted on Jan 09, 2010
We just got a Lanier 6540 Copier donated to our center. I am trying to get it to work, but we weren't given any sort of manual for it and I can't find anything on the internet. I think it is too old for...
We also just had someone donate this same type of copier to us and do have a manual. We are currently having trouble with the stapling unit running continuously. The manual is about 130 pages. I may be able to scan it to you in a few days if you'd like.
Oct 18, 2010 | Lanier Office Equipment & Supplies
The copies on our Lanier/7313 come out zebra stripped. The copies appear to copy better if we change the copy darkness to a lighter color.
Zebra striping is typically caused by a bad development clutch. Most likely, the developer and the development clutch will need to be replaced, but the 7313 is so old you may have trouble finding parts, or finding a technician to work on the machine.
Sep 21, 2010 | Lanier 1205 Copier
How do I reolace the toner in a lanier 7313 copier.
Jan 07, 2010 | Lanier 1205 Copier
How do you enter simulation mode and the code when you replace developer on lanier 7313.
Press C00C or C interupt key 0 interupt key and 41 for developer counter display 42 for developer counter clear 46 for exposure level adjustment 72 for maintenance preset counter setting 25 for automatic developer adjustment. 40 for developer preset counter display.
Nov 10, 2009 | Lanier Office Equipment & Supplies
Wrench (repair)light is on. It's a Lanier 7313.
Set the maintenance counter:perform test command 72.Press C - interrupt key - 0 - interrupt key - 7 - 2 - PSW.The currently set maintenance cycle code is displayed and the ready lamp lights up.After the ready lamp lights up anter the set code corresponding to the maintenance cycle mode.0 = 10000 sheets ; 1= 15000 sheets ;2=30000 sheets.See the toner full detection part and remove the wastw box,change it.Perfor the test command 14.This command used to cancel troubles other then U1 and U2.After cancellation of trouble the test command is also cancelled automatically,also used to cancel toner full detection the maintenance lamp blinking.
Sep 23, 2009 | Lanier Office Equipment & Supplies
I have a Lanier 7313 Copier which doesn't copy properly. Even with a new ink cartridge, the copies come out faded. Any ideas on what I can do?
Aug 24, 2009 | Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
LANIER COPIER 7313
Thanks Jason
Aug 15, 2008 | Office Equipment & Supplies
Oct 13, 2007 | Office Equipment & Supplies
101 people viewed this question
k24674
