Question about Dyson Ball DC24 Bagless Upright Vacuum
JOHNSON DF651(22)LG MOTOR FAULTY CAN WE GET BRUSHES OR,IF NOT WHO SUPPLIES AND WHAT PRICE
Change motor brushes on Fein vacuum
If the vaccuum was used with large amount of fine dust , most times the filters are largely shut beaten ,beware also of the electric field look its color to get a indication of the expectation of the remaining running time of the motor. 80% chance by use of fine dust the motor can better be replaced instead of replace brushes because the brushes are in a short time again shorted because of 1 collector in the armature , or get an equivalent motor if you can get FIXAPART motor or a original replacement if the remainder is still in reasonable condition.
Some brands of vaccuums uses the same motor could be sometimes an option because of the price.
Sep 07, 2012 | Fein 9-55-13 Turbo II Bagged Canister...
Nilfisk vacume bearings
Hi There, If you could provide the model number of the machine that would help. However as a general rule if it is the motor bearings you are after then normally you replace the entire motor. If it is the roller brush you are needing bearings for you can get them from any bearing supplies store. If you are looking for any nilfisk parts in Australia then vacuumspot is the go.
May 27, 2012 | Vacuums
My DC500 works fine running on battery power, but the motor hesitates for a moment or two when the unit is switched on with ac power. After this it works fine. What might be wrong?
may be the carbon brushes are short or motor connectors have become bad connection by moisture and dirt by use temporay a wrong filter sometimes its a very light and simple motor johnson motor with hammer brushes
DeWALT DC500 Type 1 Vacuum Parts
Mar 13, 2011 | Dewalt Vacuums
Brush will not rotate and the belt is on,is there a motor just for the the brush?
No there is not, if the main motor is turning then the problem is that the brush is jammed with debris. You need to remove the brush and clean out the debris or replace the brush assembly.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 26, 2011 | Eureka 431A Optima Bagless Upright Vacuum
Dyson DC17, front roller motor stopped
Are you sure it's dead? The motor will turn off if there's too much resistance. Unplug the vacuum, remove the obstruction, plug it back in and then firmly press the beater brush on/off button which is located next to the main on/off button.
Apr 04, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson 17 Brush Motor not working. I was an idiot
I am so sick and tird of this happening to me- it seems like the sammlest things cause my brusj motor to stop. It has happend 4 times, 3 of which were covered under warrenty and cost $80 in shipping to have fixed everytime!!! I am now out of warrenty and refuse to pay that kind of money for a machine that was alreaydy over priced. So I would love to know if you found an answer to your question...
Dec 05, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Carbon motor brush source?
unfortunatly the only way you could purchase the carbon brushes is from a vacuum parts dealer directly. the brushes will most likely end up costing you close toth price of a new motor anyway. sometimes its best to just get a new motor as the newer designes rotate teh brush much faster for better cleaning.
Oct 25, 2008 | Filter Queen Majestic Canister Vacuum
Shopvac motor not working
Then the motor brushes may be worn, or a winding is open circuit. Sears is pretty good at replacement parts, and they probably can supply just the motor assembly.
Jul 26, 2008 | Vacuums
Brush motor failure
Looking at the parts breakdown, the motor must be in the nozzle asm. part # 75213 and sells for about $25.
Dec 01, 2007 | Eureka 421A EZ Kleen Bagless Stick Vacuum
Dyson Ball DC24 Bagless Upright Vacuum Logo
442 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
