Question about Vehicle Parts & Accessories
Central air conditioning unit
My central air unit will run alday and at night the fan outside will stop blowijng and the whole system will shut off and will not work until the next day
    Top Expert:
  • Vehicle Part... Master
  • 12,223 Answers
You must do the maintenance . Call to the tech for to make the maintenance required. to due the activity of work.
God bless you
Posted on Jul 19, 2013
Central heating and air fan not working
it may have frozen and loosened someting it might just need to be seviced
Feb 27, 2014 | ATP HVAC - Heating, Ventilating, and Air...
Heat pump problems
Some heat pumps have high and low pressure swiches installed to keep compressor from running when unsafe conditions occur that can damage the compressor. If the outside fan is not turing on, the unit is cycling on high pressure, if you see ice forming on the big refrigerant line coming from the air handler, then the compressor is shutting down on low pressure. Low pressure can be cause by lack of air flow through air handler or from a low refrigerant charge.
Feb 13, 2014 | Intertherm Heating & Cooling
My trane xe 1000 central air conditioning unit turns on and the fan os working, but no air is coming into tue house. The lines get ice on them outside. I left it off all night with no change in status
If you left it off all night and no air is coming out of supply registers then the blower motor is not running. If the system is getting frost on the suction line(the big copper line coming out of the outside condensing unit with rubber insulation on it) within minutes of turning the system on then that will confirm that the blower motor is not running properly.
Unless you are very experienced in working on air conditioning, i would call a professional to do the repair.
If the motor has to be replaced its takes an experienced technician to do it correctly.
It could simply be the run capacitor on the blower motor.
This is probably going to be a 5 mfd capacitor.
Turn off all power to air handler, remove service panel, set your multi-meter to mfd (microfarads),
place the leads on the connections on top of the capacitors securely for 5 seconds. You should read about 4.8 to 5, if not the capacitor is bad.
There are other possible problems that could cause your symptoms, but ultimately your blower fan is not blowing air.
Sep 01, 2011 | Heating & Cooling
Panasonic air conditioning model no cu-v9ckp5 inside unit switches on but no fan operation outside unit starts then after approx 1 min whole thing shuts down again
The outside unit has a fan capacitor and it must be faulty!!! thae capacitor tells the fan to rotate and if the fan does not work then the compressor will shut down due to a high head pressure and temperture!! change the capacitor located in the electrical section of the outside unit and it should work fine...
Sep 10, 2009 | Heating & Cooling
Fan on outside unit will run for a while and then will shut down but inside will stay running already cleaned coils on comp can motor on outside be going bad
look at wires if only two on contactor and one on capacitor then motor going bad hard or rough to turn not sure on this model but some units have a fan cycle switch that would bring on fan
Jun 10, 2009 | Ruud Central System Air Conditioner
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Central unit freezeup when on
If you are running the unit in the A/C mode with the fan in the automatic position it could be the cause of the freezing of the coil. Try operating it with the fan in the on position and see if the problem goes away. When in the automatic operation the fan shuts off when the cooling unit shuts off and air circulation stops. Hence no defrosting of the cooling cycle in the off cycle. In the evenings when the outside temperature drops after sundown the pressures in the system drop in proportion dropping the temperature of the cooling coil sometimes causing ice formation on the cooling coil.
May 22, 2008 | Weather King 10AJA2501AH Air Conditioner
Airconditioner problem
This unit has a bad Start/Run Capacitor or a bad Fan Motor! Replace the $10 Cap...An then the $90 fan motor if the Cap dont solve it!
Oct 01, 2007 | Heating & Cooling
Vehicle Parts & Accessories Logo
67 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
