Enabling boot device
When I turn on computer, I get blue screen with "Intel Desktop Boards" at top. I hit F2 to run setup and get "Bios Setup Utility." I click on Boot and see that both boot devices are disabled for some reason. Note on sidebar says, "A device enclosed in parenthesis has been disabled in the corresponding type menu." Been trying to figure out how to enable them, but can't seem to. Please help!
    Top Expert:
  • 12,223 Answers
The best way restart the computer HOLD the keys CTRL or FN +f11 or f12 depend of your mark, model, and go to restore to the factory default. and restart again.
God bless you
Otherwise if the problem persis with blue screen, you must go to website computer supplier and get the suppor via ONLINE chat, for indication exactly, what goes on with your computer, you can RUN the software diagnostic coming with your computer or download from them.
Posted on Jul 19, 2013
SOURCE: No boot device available
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Posted on Sep 25, 2008
mumma_1
  • 903 Answers
SOURCE: My Dell laptop will not boot up
Make sure that there is no cd inside the cd rom or floppy in the drive (if your laptop has a floppy drive),
Then go back to bios (F2), and choose your hard drive as priority boot option 1, save and exit.
As you computer boots up press F8 to get an option screen on how you want to start windows, select Last good known configuration. Hopefully this will boot your laptop.
Posted on Nov 20, 2008
  • 31 Answers
SOURCE: no boot sector on internal hard drive
If the bios or setup utility can't detect your hard drive then this can be a physical problem. I suggest that you reseat or tighten the cable connecting your hard drive to the motherboard. You need to open the hard drive panel then unplug and replug the hard drive cable.
Posted on Jun 10, 2009
SOURCE: Can not start HP mini
the hard disk must have gone bad, so when you go to bios go to diagnostics and run a test on hard drive, most probably if it fails , u need to replace the hard disk so call hp and u can replace the same
Posted on Oct 22, 2009
  • 916 Answers
SOURCE: Won't turn on
No bootable device usually means that your hard drive has failed. It is either not connected properly to the computer or the drive needs to be replaced.
Posted on Oct 27, 2009
POST
For Intel Desktop Motherboards
To Enter BIOS setup, Press F1 or F2 at startup.
To Select Boot Device, Press F8 at the startup.
To save changes and exit BIOS setup, Press F10.
May 15, 2012 | Intel Desktop Motherboard - Intel 910GL...
PC RUN normal: the configuration BIOS STOP and message is: configuration is ok! Problem upgrade failed! use F1 for setup continue or F2 for chancer manual setting DATE/TIME.Thank you.
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 08, 2011 | Computers & Internet
Hi, i want to set up cd drive on first boot. How do i can access to setup?
If I don't know what computer you have It makes helping you more difficult.
Here are some options for different computers:
  • Turn on the computer, immediately hit the F2 button. - Most computers with Phoenix BIOS.
  • Turn on the computer, during POST hit the Delete button - Most computers with AMI BIOS
  • Turn on the computer, hit Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1 - Older Lenovo.
  • Turn on the computer, immediately hit the F10 button. - Some Dell computers.
  • Turn on the computer, hit Fn+Esc or Fn+F1. Older Dell laptops.
If you tell me exactly what you have, I'll tell you exactly what to do ;)
Jan 28, 2011 | Computers & Internet
ACER first it said this ntel UNDI, PXE-2.1 (build 082) Copyright (c) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.13(2008/10/15) Check cable connection..! PXE-MOF:...
Press F2 on boot. go to bios, ie insydeh20 setup utility. goto boot menu. select legasy in type. select your usb drive and hdd as a first boot device. save and reboot.
Jul 02, 2017 | Acer Aspire One PC Notebook
Does not boot. displays intel desktop board in blue screen
Blue error message comes when there is any issue with memory.
First Refix your RAM memory.
Then boot your computer with recovery disk.
For that you have to set first boot device as your cd or dvd rom .
When you power up the computer press F1 or F2 or "del" key then you see bios setup screen.
Then go to boot option and set first boot device as cd or dvd.
Then put bootable disk in computer then it boot with it.
Then follow the procedure on screen.
choose "R" option for enter in "Recovery Console"
Then type in prompt "chkdsk /r"
then it fix error on harddisk then then restart computer then if still same issue then you have to repair your windows with recovery disk.
Let me know if you need more assistance.
Thanks.
Oct 03, 2009 | Intel D845GEBV2 Motherboard
Recover BIOS d845gebv2 motherboard my motherboard does not boot.monitor displays intel desktop board in blue screen
Right after you power the computer on start tapping F2 rapidly on the keyboard until you are in the BIOS setup. When you are in the BIOS setup, check to see that the computer recognizes your boot device and that your boot order is correct. Also, if you have changed any jumpers on your mainboard; change the back.
Sep 19, 2009 | Intel D845GEBV2 Motherboard
Disc failure 0 press F1 to continue
He has accessed the bios and change the boot setting devices by enabling the floppy drive which you do not have.
Go Bios (F1 or F2) on first screen. and select load default setting
Also go to Boot Options and make sure 1st boot is the HDD not FDD or removable disk
Also in any menu mention of Floppy Disk make sure it is set to not installed or disabled.
keep me posted
May 21, 2009 | Dell Vostro 200 Desktop Computer Intel...
Dell GX260
You need to change the boot order in the bios of the computer. It is also called the setup. When you turn the computer on, in the top right hand corner of your screen you will see F2-Setup F12-boot menu. Select F2 and when you get into the bios go through the options until you find "boot order" or just "boot". That will show what devices your computer will use, and in what order, to boot up. If the floppy is below the main hard drive then it won't work unless the hard drive is defective. Move the floppy to the top of the list, exit saving changes, and it will now check the floppy first.
Dec 11, 2008 | Dell OptiPlex GX260 PC Desktop
Update my Intel D845GVSR Bios Version to VA84510A.86A.0056.P20, then my USB driver is not working at all.
I followed the suggestion of changing the BIOS configuration to the recovery mode, however one thing was missing - it required a startup disk and I didn't have one. I then changed the BIOS configuration to the config (pins 2 & 3) mode, booted up and went to the BIOS/CMOS setup and a new menu tab appeared called "maintenance". I went to the advance tab and selected USB configuration and, instead of a blank screen, there appeared a selection for USB support and it showed disabled. I changed the setting to enabled and three more lines of information regarding USB came up, but required not further changes. I went to F10 and saved and exited and I now have me USB capability back.
Mar 10, 2008 | Intel D845GVSR Motherboard
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
