Question about Air Tools & Compressors
I have broken off a Orifice tube in a 99 blazer and can't get it out. Any suggestions? It is all the way at the back of the tube. Do I need to change out the evaporator and how do I do that?
  • Air Tools & ... Master
  • 17,093 Answers
Replace the whole thing. There are retrofit kits for it. You may have to cut the tubing to do it. Then you put in the kit and make sure all the seals are tight. Otherwise you may need to use a set of oring picks to see if you can get it out. Be careful that you dont mar the inside of the tube though
Posted on Jul 21, 2013
Changing ac expansion valve on 05chevy trail blazer
Late models do not have an expansion tube as such, I think. Rather you have an orifice tube, usually located in the line where the high side line goes into the evaporator fitting under the hood near the firewall.
Jun 21, 2015 | AC Cars & Trucks
Where is the orifice tube on 99 gmc sonoma pickup
The AC orifice tube is located in one of the metal portions of your hoses. It may be identified by about a few inches from the nut you shall see four small indentations around the surface of the tube. This filter is located inside the tube and usually needs a special extractor to remove.
Good Luck
Mar 16, 2015 | GMC Cars & Trucks
Honda Civic Orifice Removal and Replace
Does 1993 Honda Civic equips with orifice tube or just expansion valve?
May 11, 2013 | Honda 96 97 98 99 00 Civic Ac Compressor...
Where is orifice tube located in the a/c system
Hi, Orifice tubes are located in the high pressure line where it goes into the evaporator (close to firewall) or the condenser ( close to radiator) or in the line itself. I believe in my jimmy (about the same as a blazer) it was near the firewall where the high pressure line unscrews. Unscrew the line (think its a large coupler) and it should be inside there. Clean the cavity of any dirt or debris well and note the direction of the old orifice for installation.
Please rate this answer......Thanks! Mike
Jun 14, 2011 | 1999 Chevrolet Blazer
Ac cycles on 92 blazer ,new compressor,low switch bad?
Did you replace the dryer,and the orifice tube?If the orifice tube was not replaced,this is most likely the problem,what are the pressures while it is running,and how much freon is in the system?If the system does not have enough freon it it,it will do this,but if it does,the cycling ac compressor is because of the orifice tube,if the system was not flushed out,and there was a new orifice tube installed ,then it is stopped up again.Let me know something so I can help.
Jul 14, 2010 | 1998 Chevrolet Blazer
Where is the orifice tube located in the a/c system?
The orifice tube should be located inside of the metal AC line from the condenser. The discharge hose (from the compressor) connects to the top on the condenser (inlet). The orifice tube mounts in the bottom of the condenser (outlet to the evaporator). The outlet tube of the condenser has a 45º upward angle. If it is not in that location it will be farther out on the same line where it connects. Here is a diagram that might help.
Jun 10, 2010 | 1996 Chevrolet Blazer
When changing A/C compressor on 99' chevy suburban 1500 what all needs to be changed or done besides the flush, vacuum and freon.
there is either an orifice tube or a expansion valve. both do the same job. however, the orifice tube should be replaced. it will filter small particles from the system and gets clogged. i would also replace the accumulater or receiver/dryer and condensor. if your compressor went bad chances are there is a lot of debris in the system. flushing doesn't always remove the debris. there is much more info on the internet regarding this subject. as well as videos on you tube
May 21, 2010 | 1999 GMC Suburban
Where is the orifice tube located on a 1993 Chevrolet Blazer?
a/c orifice tube is on discharge line before filter dryer side the line.
Jul 12, 2009 | 1993 Chevrolet S-10 Blazer
Looking For orfice Tube on 2000 Grand Prix 3.8 Liter .need to change it if it has one along with accumalator
Recover the refrigerant. Remove the engine air cleaner.Remove the vacuum brake booster. Remove the condenser tube. Remove the expansion (orifice) tube: Use needle-nose pliers in order to grip the orifice tube. Use a turning motion along with a push-pull motion in order to loosen the impacted orifice tube. Remove the orifice tube.
Important: DO NOT use any solvents or chemicals to clean the expansion (orifice) tube porous plastic inlet filter. Inspect the expansion (orifice) tube for the following conditions and clean or replace with a new tube as indicated: Broken plastic frame, Inlet filter damaged or plugged with fine gritty material, replace tube. Inlet filter coated with metal chips, flakes, or slivers; coating may be removed with low pressure shop air ONLY and reused if cleaned satisfactorily. If reusing the tube, discard the O-ring seals and replace. This is from the gm service CD manual. keep me posted and good luck
Jun 29, 2009 | 2000 Pontiac Grand Prix
I just changed my air condition system
on pass side underhood you will see reciever/drier(large line goes to it,Then you will see small ac line by it,disconnect small line, orfice tube is inside it.
Jun 19, 2009 | 1999 Chevrolet Blazer
Air Tools & Compressors Logo
82 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
