Question about DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
Jewelry Scale there are three h's on the screen
What does it mean when the jewelry scale read over
Jewellery scales are light, so if you put a bag of sugar ion it, it will show an error.
If you mean you put a 1 gram weight on it and it shows over, then it can be three things. One is that the tare is out, so you need to zero it empty. Or your 1 gram weight has been fiddled with, or, the scale is faulty.
Apr 24, 2016 | Health & Beauty
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Can i replace the battery in my Royal EX2 Exacta Scales Postal scale?
90 day warranty on this scale to begin with so when battery dies after 10 years, you have no warranty to preserve. Royal EX2 Exacta Scale - royalsupplies.com - manual downloadable.
You will need a Phillips #1 and I think a #0 for best fit. 2032 lithium coin battery (fresh, so it will last another 10 years). 1) Peel off large label from bottom (Xacto knife to get under a corner). 2) Remove 3 screws attaching pan to mechanism. Use magnitized P0 screwdriver here. 3) Remove 4 rubber feet, and four P1 screws under them. 4) Opposite side of display from the button is the black battery case. Use P0 screwdriver to remove three screws. Replace battery. 5) Put back together...
Don't mess with the mechanism inside (at least not if you want a calibrated scale) any more than you have to while changing the battery.
Jul 04, 2012 | Health & Beauty
How to fix an easy weigh digital scale
the 24c02 is a memory chip inside. Unless your a tech - you can't repair.
Jun 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Need instruction manual for JR Ohaus 300 scale
The Operating Manual for the Ohaus 300 Compact Jewelry Scale may be downloaded here:
http://www.ohaus.ca/PU/PDF/IM%20RUBY%20EN.pdf
Jan 08, 2012 | JR Ohaus -300 Ruby Jewelry Scale, 300 x...
My scale is frozen displaying f--h how do I fix this? I tried holding mode and tare and turning it onon and that doesn't work any other suggestions?
Reset it!
Turn off the scale. Press and hold the MODE button and turn the scale on. Release the MODE button you will see the scale's internal count.
Press and hold the TARE button then press (don't hold) the MODE button you will see the full capacity is changing. Keep pressing the MODE while holding the TARE button until you see 100.00 on the screen. The reset is completed. You may need to recalibrate the scale after the reset.
Nov 09, 2010 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
CALIBRATING A TANITA KD-200-110 DIGITAL SCALE.
According to Tanita, you must send the scale back to the factory to adjust the calibration. As of September 2011 the cost is $125.00
This is more the scale costs.
Moral of the story. Don't buy Tanita.
Aug 24, 2009 | Tanita 1479V - Digital Pocket Scale /...
DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
26 people viewed this question
Top DigiWeigh Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
