Question about Tools & Hardware - Others
Ryobi bd4600 M;y BD4600 stopped running during a prolonged sanding session. The motor now hums at switch on but the belt does not turn until it is pushed, then it will run. Question, it it Item 31 the Capacitor or Item 34 the Start Relay?
2 Suggested Answers
  • 384 Answers
SOURCE: I have a Ryobi 4x36 Belt Sander (BD4600). I've
Look for plastic build up in the motor. Try to air blow motor and belt drive.
Posted on Jun 16, 2009
I have borrowed a ryobi industrial belt sander, I have put the sanding belt and repositioned the latch. When running the sanding belt keeps moving out.
There will be a tracking adjustment somewhere, usually a knob or wheel located at one end (axle) of the sander that allows you to adjust that... run the sander at low speed while you turn it until it tracks straight
Jun 10, 2011 | Tools & Hardware - Others
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
Skill belt sander belt stops moving
most belt sanders are simular,if you have right size belt,there should be a lever between the belt wheels,pull lever out,put belt on,then close lever,some also have adjusting knob,turn clockwise to tighting.
Sep 30, 2009 | Tools & Hardware - Others
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Belt slipping
I have a Ryobi sander with a belt slipping issue as well. The problem seems to be in the design, not on the user end. The drive barrel is made of a semi-hard, non-gripping material. Wood dust becomes a final release agent that breaks any grip that the barrel may have had.
To compound the problem, the more the belt slips the smother the underside becomes allowing for greater slippage.
I now know why this model was the least expensive unit. >.<
Jan 08, 2009 | Tools & Hardware - Others
Loose sanding belt
Hi, Consult your user manual for the instructions to install a new belt.  Follow these instructions selectively to tighten the belt tension. Here they are....
CHANGING DRIVE BELT
  Using a phillips head screwdriver, remove the two screws
in the center of the pulley cover.
  Remove the cover.
  Raise sanding belt to the vertical sanding position.
  Next, loosen the hex head set screw. Raising the motor
pulley releases the belt tension.
  Remove the old drive belt.
  Fit the new drive belt on the drive pulley first and then on
the motor pulley.
  Test belt tension by squeezing the belt with your fingers.
  Adjust the belt tension with the hex head set screw until
there is about 1/4 in. (6 mm) of give.
  Tighten the belt tension nut securely.
Note: Excessive tightness on the drive belt may cause
increased noise and overload the motor. Excessive
looseness on the drive belt may cause the drive belt to
fail prematurely and make a severe chattering noise.
  Using a phillips head screwdriver, reinstall the pulley cover
and the two phillips head screws. Tighten securely.
Good Luck!  Middles
Tools & Hardware - Others Logo
50 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
