Question about Garden
247.28933 Do you have to take the deac off to fix the blade timing?
    New Friend:
  • 17 Answers
What do you mean belt timing? There's no such thing?
Posted on Jul 20, 2013
Sharpening blades for qualcast 35s
With a cylinder mower the sharpness of the blade is only part of the concern. The fixed blade is like one of the blades of a pair of shears and each "blade" of the revolving cylinder acts as the other.
As long as only grass is being cut (no stones) the blades will last a long time with only occasional adjustment to the fixed blade as per instruction manual.
After much use or in case of damage the fixed blade will need replacing or sharpening. If it is badly worn it will need removing and sharpening by a specialist with the correct equipment but otherwise the light application of a file, stone or a patent sharpener and then readjust the blade per manual.
When eventually the cylinder becomes worn or sustains damage it must be removed and machine trued and sharpened using a lathe or similar.
An accurately sharpened cylinder and a true and sharp fixed blade correctly adjusted will consistently cut paper across the complete width of the blade when turned by hand. A competently sharped and adjusted cylinder mower will cut the thinnest tissue like the finest scissors without binding.
Aug 18, 2016 | Health & Beauty
Wiper blade timing
They should. Poor old car. I hope you have changed the oil a few times.
Jan 18, 2013 | Toyota Camry Cars & Trucks
If my machine is not cutting right do I need to replace both blades
not necesarily, can you see a knick in either of the two blades? use a magnifying glass and see if you can see any damage first.
Then try changing the fixed bottom blade only first, you may have got a replacment top blade in your accessory bag new with the machine.
The blades themselves are very high grade steel just like scissor blade so should last for quite a long time, provided they don't come into contact with a pin.
You can buy the bottom blade for your machine here http://www.sewingpartsonline.com/lower-knife-babylock-60544.aspx along with the top blade and other spares.
Also, remember to clean the blades of lint regularly and give them a wipe with a cloth moistened with a little clear sewing machine oil from time to time.
Jul 06, 2011 | Simplicity Serge Pro SW432 Mechanical...
Level 5 on the deck height is where I would want 3 to be. How do I raise the deck? I tried the front screw which just raises the front. The 3 holes on the rear end of the deck don't make any differnece...
look under the mower like down below the seat , there should be a bolt on one or both sides ,this is for the back of the mower deac. If not ,raise the deck all the wau up and adjust by th front bolt
May 26, 2010 | Troy-Bilt Pony Garden Tiller
Raising and lowering the blade is really tight.
what I do is turn it over and using compressed air blow out as much of the dust as you can and then find a dry silicone type lubricant to thoroughly spray the threads and the slide portion of the saw. let dry and then move blade up and down a few times, you might have to repeat this but it works.
May 23, 2010 | Dewalt DW744X 10" Portable Table Saw
New mower hit small stump, cuts too low now/ can't adjust height
It is a bend blade. I feel your pain...I had a riding lawnmover that took a good two-hours to take apart and chage blades and 3/4 of an acre with old ornamental garden root balls popping up all the time. That was a long summer...
You may want to get the blade ahead of time so whomever can help you look under the mower can change the blade once they confirm it is bent. Even if they can fix the old one it is a blade you will need sooner or later and they are not very expensive.
Dec 17, 2009 | Garden
I have a MTD Pro riding lawn mower that I
the only way to fix it is fit the right blades
they have fitted the wrong blade's to it,,,
the blades should overlap when cutting the grass they cannot crash into each other as there are (timed up) not to do that the new blades they fitted are to short so you have no over lap on the gutters that leaves a strip of grass left uncut between the blades,,
call them out to put this stupid mistake right,,,
Oct 25, 2009 | Garden
Kx-TGA641T how does one unblock blocked number
http://ww2.justanswer.com/uploads/MCVGreg/2009-09-21_023145_KXTG9331-Remove-Blocked.pdf
Viewing/editing/erasing block call
numbers
1 {MENU} -> {#}{2}{1}{7}
2 {V}/{^}: Select the desired item.
~To exit, press {OFF}.
3 Proceed with the desired operation.
■ Erasing a number from blocked list:
{Erase} -> {Yes} -> {OFF}
you can also edit:
■ Editing a number:
{Edit} -> Edit the phone
number. -> {Save} ->{OFF}
Sep 28, 2009 | Panasonic Lands Phones
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
