Question about Coffee Makers & Espresso Machines
Nespresso fna1 I have a Krups Nespresso Coffee Machine. Not used it for a while, now when I switched it on the motor whirls but no water comes through. Does it need descaling and if so how can it be done if the water does not flow through them machine.
Noggin
  • 944 Answers
SOURCE: Krups Nespresso FNA2 coffe/cappucino machine
First thing to try is a descale. Run the machine normally using it (as if making a cup of both types) a couple of times with a 50/50 mix of white vinegar and water. Leave the machine off but uncleaned overnight. run a couple of cycles with just water, and if there is still a slight vinegar taste then run a cycle with a teaspoon of baking soda in water, then flush with just water again. If this doesn't solve the problem, try again with 75% vinegar. If still not working, there is either a control board problem (may be solveable), or the valve/solenoid that stops/allows the water is sticking, almost certainly solveable by taking that apart and cleaning/lubricating. Definitely solveable by replacement. Let me know what you get after a descale if no luck. Hope this helps :)
Posted on Aug 20, 2007
SOURCE: Nespresso D300
Have you tried descaling it. This message displays when it's time to descale and I don't know of a way to turn it off without descaling it.
Posted on Aug 13, 2008
SOURCE: water leaks from the top of the C190 Espresso Machine
in our case the problem was fixed easily: the metal piece in which the capsule sits is screwed in on the top. When it became loose our machine started to leak water from the top. So the problem was solved by retightening it!
Posted on Feb 02, 2009
  • 21 Answers
SOURCE: water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Posted on May 08, 2010
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Posted on Sep 05, 2010
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
Nespresso not making any noise, water not coming out
return it to place of purchase as defective w/ receipt
Oct 06, 2017 | Krups Nespresso Citiz And Milk
User Manual
Here you go...good luck! :) http://kitchen.manualsonline.com/manuals/mfg/nespresso/c290_d290.html
Aug 28, 2012 | Krups Coffee Makers & Espresso Machines
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
Nespresso Krups essenza manual XN2001- Switch broken
The machine is not switching on-I am in India-Tamilnadu-can i get it serviced any where here?
Jul 29, 2009 | Nespresso Essenza C100 Espresso...
Water leakage inside
Use less water....
Apr 29, 2009 | Krups Nespresso 554
Krups nespresso not heating water
That is a faulty thermostat or a defective control board.
Contact Krups and have the machine replaced.
Contact - Krups International
Feb 17, 2009 | Coffee Makers & Espresso Machines
Machine won't work
This machine does not have that muck electronic, the button switch has probably a short, and must be replaced.
As said the machine is Krups, and therefore should be covered with one year warranty. Call the number listed on the user manual, or find contact from websites below:
Coffee & Espresso Machines - Small Domestic Appliances - Krups
Home - Krups UK
Jan 03, 2009 | Nespresso Aeroccino Automatic Milk Frother
Coffee Makers & Espresso Machines Logo
47 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
