Question about Kenmore Heating & Cooling
Kenmore Model 253.70151010 - Blowing fuses
I bought this unit new about 3 years ago and have never had problems with it until recently. I have it on a dedicated circuit protected by a 15 amp fuse. When the problem began, it would blow the fuse about once a week, then once per day, and now once every few minutes. I plugged it into another outlet on a different circuit and it blew the 15 amp fuse on that circuit after a couple of minutes. While it's running, it puts out cold air like it did when new. What could be causing this problem?
  • 11 Answers
SOURCE: HBD 160-H Hampton Bay Air Conditioner
The fan alone on an A/C unit draws alot less amps than a fan and compressor. I would guess that your fan and compressor draw around 15 amps when bnoth are on. The unit should be on its own breaker or fuse (whichever you have. As things get old, like fans and compressors, they wear out and will draw more amps.
I see you have 2 choices,:
1) place the A/C on its own circuit with nothing else on it. This may buy you some time until you can replace the unit.
2) Buy a new A/C as the newer units are more energy efficient, and last longer.
Posted on Jul 08, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Will not cool properly.
You have either a faulty thermostat, dirty condenser and evaporator or a faulty run capacitor. Need to service soon before the compressor is damaged. Sea Breeze
Posted on Jul 06, 2009
  • 340 Answers
SOURCE: Constanly blowing fuses in thermostat
u have a short some place jumping the fuse wreck the transformer controls good luck Tom
Posted on Jul 07, 2009
luker711
  • 91 Answers
SOURCE: I have a Ruud air-conditioner/heat pump and it blows 5 amp fuse.
It sounds like the thermostat wire going to the condenser is ground, It either got pulled loose and is touching the housing or as in most cases the wire got cut or was chewed by an animal. You need to turn electric off to both devices and physically inspect the thermostat wire going from the air handler to the outside unit, also inspect where they connect inside the unit. When you find the break, cut and strip each individual wire and securely wire nut each conducter red to red white to white and so on. There you go all fixed. That's when I give you the bill for $75...except this time you write that check to yourself. Good Luck
Posted on Jul 14, 2009
SOURCE: Unit is running, but is no longer cooling. Fan is
not sure if it is a package system or a split but this is what you do.go outside where your outdoor machine is, after it has been shut off for awhile, and you should hear 2 distinct noises.1 is the outdoor fan, you should see it spinning.the other is a comppressor hum.some compressors have noise bags on them so listen closely thru the fan noise.if you hear no hum listen for a hum about every 2 to 5 minutes.if you hear this hum every so often, chances are you compressor is seized or stuck.the only thing to do there is get a tech and try a big boost to get it going.
Posted on Aug 08, 2009
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
My Amana package system fan only blows cold air
a fuse blows for a reason. dry bearings will increase amp draw, a non rotating fan rotor will blow a fuse. burnt windings will almost instantly blow a fuse. just changing the fuse may not solve your problem. find the problem and fix it THEN replace the fuse.
Oct 20, 2009 | Amana PTH153B50AE Air Conditioner
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Micro/Oven fuse keeps blowing
Disconnect the connector to the primary winding of the high voltage transformer. Put a new fuse . If the fuse is not blowing the problem may be in the secondary side of the high voltage transformer. Chek the highvoltage diode, capacitor, magnetron respectively. you can also check the primary winding of the low voltage transformer.
May 23, 2009 | Microwave Ovens
I have a Kenmore series 80 that I bought it used two years ago, it now has a bad motor, it was manufactured in '96. I replaced the motor coupling a month ago. My question is, is it worth replacing the...
hello, i'ld say buying a new motor is far cheaper then buying a new unit unless the maching is in bad condition for a new motor your looking at anywere from 50.00-175.00$ depending on the model number of your machine. good luck on making your decision, and if you decide to buy the new motor and need help finding one let me know i can help you find the motor you need.
Mar 22, 2009 | Kenmore 24442
Convection/microwave/fan above stove unit--cannot figure it out
Hi belson,
I'm Harvey the Master Plumber.
Your problem is: You bought a Kenmore Elite Advantium 120 tech model from Sears about a year ago and you cannot find the manual and you have no idea how to perform any of the functions. You did manage to set the clock. It is not user friendly and you need a new manual or some directions. Thanks.
It has been my experience that this company will be happy to help. The next time you're at the store just tell the appliance sales rep your problem and he'll make sure you get a manual.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Oct 05, 2008 | Kitchen Ranges
Kenmore dryer won't start
your blowing that many thermal fuses, id replace all the thermostats. (2) come in one kit both on heater box 1 top and one bottom. id also look into your venting, a clogged fo kinked vent is going to overheat the unit and blow all sorts of stuff(not to mantion the potential fire hazard of a bad vent
Mar 19, 2008 | Dryers
Projector Problems
Sounds like the fuse popped. t5a=5 amps 250v=250 volts So you will need a fast-acting 5 amp 250 volt fuse
Mar 14, 2007 | InFocus ScreenPlay 4805 Multimedia...
Heating & Cooling Logo
50 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
